WiFi cannot change channel after unsuccessful wifi connection
HelterSkelter
Postby HelterSkelter » Tue Mar 18, 2025 12:32 pm
I have an issue with changing WiFi channels if the ESP32 does not connect to the Wifi. I have made a code to illustrate my issue:
#include <WiFi.h>
#include <esp_wifi.h>
const char* ssid = "Test";
const char* password = "Test";
#define WIFI_CHANNEL 8
void ChangeChannel(){
esp_wifi_set_promiscuous(true);
esp_wifi_set_channel(WIFI_CHANNEL, WIFI_SECOND_CHAN_NONE);
esp_wifi_set_promiscuous(false);
Serial.printf("Channel after ChangeChannel: %u\n", WiFi.channel());
void setup() {
Serial.begin(115200);
WiFi.persistent(true);
WiFi.mode(WIFI_MODE_APSTA);
Serial.printf("Channel after Mode Set: %u\n", WiFi.channel());
ChangeChannel();
WiFi.begin(ssid,password,WIFI_CHANNEL); // Attempts to connect using stored credentials
int counter = 0;
Serial.println("********************CONNECTING********************");
Serial.print("Connecting to WiFi ..");
while (WiFi.status() != WL_CONNECTED && counter<5) {
Serial.print('.');
delay(1000);
counter ++;
if (WiFi.status() == WL_CONNECTED) Serial.printf("\n Connected \n");
else Serial.printf("\n Not Connected \n");
Serial.printf("Channel after connection: %u\n", WiFi.channel());
ChangeChannel();
WiFi.disconnect();
Serial.println("********************DISCONNECTING********************");
Serial.printf("Channel after disconnection: %u\n", WiFi.channel());
ChangeChannel();
void loop() {
In the code, I tried to change the WiFi channel 3 times:
1. First time after WiFi.mode(WIFI_MODE_APSTA);
2. Second time after the WiFi connection attempt
3. Third time after disconnecting from WiFi.
When WiFi is available I get this on a serial monitor:
Channel after Mode Set: 5
Channel after ChangeChannel: 8
Connecting to WiFi ....
Connected
Channel after connection: 1
Channel after ChangeChannel: 1
Channel after disconnection: 1
The channel changes normally after WiFi.mode(WIFI_MODE_APSTA) and after disconnect (as it should).
The issue arises when there is no Wifi available. Then I get this on the serial monitor:
Connected
Channel after connection: 13
Channel after ChangeChannel: 13
Channel after disconnection: 13
As you can see from the serial monitor, the channel does not want to change after WiFi.begin(ssid,password,WIFI_CHANNEL) if the WiFi is not connected .
Are there any solutions available for this?
Thank you in advance,
Marin
ahsrabrifat
Re: WiFi cannot change channel after unsuccessful wifi connection
Postby ahsrabrifat » Fri Mar 21, 2025 10:52 am
Try to stop the WiFi completely before changing the channel:
WiFi.disconnect(true, true);  // Disconnect and erase credentials
esp_wifi_stop();              // Stop the WiFi driver
esp_wifi_start();             // Restart the WiFi driver
HelterSkelter
Postby HelterSkelter » Mon Mar 24, 2025 12:26 pm
That works,
Thank you very much :)
ahsrabrifat
Postby ahsrabrifat » Tue Mar 25, 2025 1:40 pm
That works,
Thanks for the update. You're welcome. :)
Users browsing this forum: Applebot, Baidu [Spider], Bing [Bot], PetalBot and 3 guests
