I've been using the FreeRTOS TCPIP stack for over 10 years on STM32F4 devices and understand/like it.
I've had nothing but issues with the ESP LWIP stack.
I ONLY use raw socket call from the stack - I have my own Server code.
When I go into the IDF Config menu and uncheck the usage of LWIP and then attempt to build - I get an error during the compiling of
v5.4/esp-idf/components/esp_http_server/src/httpd_ws.c
that <sys/socket.h> was not found.
I would NOT get the error if the IDF was NOT attempting to compile the esp_http_server which is NOT checked in the config menu.
So -- please inform me how to build the IDF will ALL LWIP source and related HTTP Server, HTTP Client, NETIF NOT in the build process.
I did this 12 years ago for the 8266 idf so it was possible then ... why not now.
I know your intention is to make the ESP32 coding idiot proof but there must be away to bypass all of your default builds.
Thanks in advance for any reply.
NOTE: Right now my biggest issue with LWIP is that is does NOT respond to ARP requests. Example - Desk Top Chrome connects with ESP32 and wants to make a TCP connection. It keeps asking via ARP to respond to the requested IP Address (using wireshark to view network activity. LWIP does NOT respond. Finally, LWIP sends a gratuitous ARP and the connection is made. LWIP sends a gratuitous ARP about every minute so you have to hang and wait. WHY no reply when ARP is requested.
How to Remove LWIP and all HTTP Server and Client
MicroController
Re: How to Remove LWIP and all HTTP Server and Client
Power saving maybe?Right now my biggest issue with LWIP is that is does NOT respond to ARP requests.
Sorry - I don't understand your reply. CPU is NOT in any power saving mode.
MicroController
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
