Executing code before flash upload
poorchava
Postby poorchava » Mon Mar 31, 2025 8:30 am
In my product, ESP32 manages its own power. As soon as possible after startup, it asserts a POWER_HOLD line which keeps the power enabled after the user has released the power button.
There is a problem with firmware update: as soom as the ESP32 is reset into bootloader, the GPIO controlling the POWER_HOLD line is reset, then device looses power and therefore the firmware update is impossible.
Is there a way to either set the GPIO state before the flash upload is executed, set default GPIO state in fuses of somehow retain GPIO state through reset?
Re: Executing code before flash upload
Postby Sprite » Mon Mar 31, 2025 12:38 pm
What ESP32 is it, and how do you update the firmware?
