my ESP32 won't connect
th0mas
Postby th0mas » Wed Apr 09, 2025 5:23 pm
Hello, I have a problem with my ESP32. It won't connect (even with the BOOT, EN, BOOT release sequence). It appears as 'USB SERIAL CH340'. I've never touched it.
Capture d'écran 2025-04-09 192252.png (1.62 KiB) Viewed 123 times
Re: my ESP32 won't connect
Postby Sprite » Thu Apr 10, 2025 12:06 am
Looks like the headers on that thing have been desoldered. I'd first check to see if there isn't a solder bridge or something that remains from that process.
th0mas
Postby th0mas » Thu Apr 10, 2025 10:59 am
I was very careful when removing them. And after checking with a multimeter there is no solder bridge.
Postby Sprite » Fri Apr 11, 2025 7:09 am
If you use a terminal on that serial port (115200 baud, n81) and reset the board, do you get any output?
th0mas
Postby th0mas » Fri Apr 11, 2025 10:03 am
No, nothing happens, neither a printout in the serial monitor nor a flashing LED. Absolutely nothing.
Postby Sprite » Sat Apr 12, 2025 4:51 am
Hm, that sounds like something in hardware is broken. Hard to say what though.
th0mas
Postby th0mas » Sat Apr 12, 2025 1:01 pm
How can I find the problem and do you think it can be fixed?
Postby Sprite » Sat Apr 12, 2025 11:50 pm
First step would be to get another one, so you can test if it's really the hardware that is broken. Second step, in all likelihood, would be to just chuck away this one as it's pretty much beyond economic repair and you already have a new one.
Franco
Postby Franco » Sun Apr 13, 2025 3:08 am
I didn't know there were still D modules versions available. The current rev is E.
Users browsing this forum: meta-externalagent, Perplexity-User, Qwantbot and 5 guests
