Unable to install esp-idf in VSCode
miskor
Postby miskor » Mon Apr 07, 2025 3:23 pm
Hello ESP32 forum,
Newbie here, having issues with esp-idf extension for (newly installed) VSCode...
I've tried different version of esp-idf and different download site but error is still the same:
Downloading https://dl.espressif.com/dl/esp-idf/esp ... s.v5.4.txt
Destination: C:\Users\misko\.espressif\espidf.constraints.v5.4.txt.tmp
WARNING: Download failure: [ASN1] nested asn1 error (_ssl.c:4004)
WARNING: Failed to download https://dl.espressif.com/dl/esp-idf/esp ... s.v5.4.txt to
ERROR: Failed to download, and retry count has expired
Please make sure you have a working Internet connection.
By downloading and using the offline installer from https://dl.espressif.com/dl/esp-idf you might be able to work around this issue.
See the help on how to disable constraints in order to work around this issue.
non zero exit code 1
Python 3.11.2
pip 22.3.1 from C:\Users\misko\.espressif\python_env\idf5.4_py3.11_env\Lib\site-packages\pip (python 3.11)
WARNING: Failed to download https://dl.espressif.com/dl/esp-idf/esp ... s.v5.4.txt to C:\Users\misko\.espressif\espidf.constraints.v5.4.txt.tmp
I've attached (zipped) esp doctor log.
Does anyone know how to fix this? Thanks!
esp-idf report.zip
(208 Bytes) Downloaded 18 times
FBEZ
Re: Unable to install esp-idf in VSCode
Postby FBEZ » Tue Apr 08, 2025 7:14 am
Hi Miskor,
welcome to the forum!
Not sure if I understand correctly. You have problems installing the extension or using it?
To install the extension, you have to use the procedure for downloading vscode plug-ins. You click on the four squares on the left (Extensions) and search for ESP-IDF in the extension search bar. From there, you just click install.
miskor
Postby miskor » Tue Apr 08, 2025 12:24 pm
Hi @ESP_FBEZ,
I was following the steps for the clean esp-idf VSCode installation given here:
https://docs.espressif.com/projects/vsc ... ation.html
But, installation in step 5 was unable to finish successfully, error was raised that I sent earlier:
In my opinion that error points out that specific file ("https://dl.espressif.com/dl/esp-idf/esp ... s.v5.4.txt") is unavailable for download from espressif web site but strange enough if I do a wget of that url - file is downloaded!
Thanks again for your support!
miskor
Postby miskor » Tue Apr 08, 2025 7:49 pm
Additionally, I've deleted all traces of esp-idf and then tried with offline installer (as suggested in the end of the error output from VScode but then different error appeared:
Installing D:\Espressif\tools\idf-git\2.39.2 ...
Extracted D:\Espressif\tools\idf-git\2.39.2 ...
Using existing D:\Espressif\tools\idf-python\3.11.2
"D:\Espressif\tools\idf-python\3.11.2\python.exe -m pip" is not valid. (ERROR_INVALID_PIP)
And that pip was installed by offline installer, I do not have any other pip or python on my computer...
Is this software some kind of a joke?
SergeyO
Postby SergeyO » Sat Apr 12, 2025 4:36 pm
Try this:
D:\Espressif\tools\idf-python\3.11.2\python.exe -m pip install --upgrade pip
It will update pip to latest version.
miskor
Postby miskor » Sun Apr 13, 2025 10:09 am
Thanks @SergeyO ,
Got new error:
PS D:\> D:\Espressif\tools\idf-python\3.11.2\python.exe -m pip install --upgrade pip
D:\Espressif\tools\idf-python\3.11.2\python.exe: No module named pip
miskor
Postby miskor » Sun Apr 13, 2025 10:15 am
when stared from esp-idf cmd prompt I got following errors:
Setting PYTHONNOUSERSITE, was not set
Using Python in D:\Espressif\python_env\idf5.4_py3.11_env\Scripts\
Unable to create process using '"D:\Espressif\tools\idf-python\3.11.2\python.exe" --version'
Using Git in D:\Espressif\tools\idf-git\2.44.0\cmd\
git version 2.44.0.windows.1
Error: The following tools are not installed in your environment.
python
Please use the Windows Tool installer for setting up your environment.
Download link: https://dl.espressif.com/dl/esp-idf/
For more details please visit our website: https://docs.espressif.com/projects/esp ... setup.html
D:\Espressif\frameworks\esp-idf-v5.4.1>D:\Espressif\tools\idf-python\3.11.2\python.exe -m pip install --upgrade pip
Access is denied.
miskor
Postby miskor » Sun Apr 13, 2025 10:25 am
and that is brand new installation...
bignacio
Postby bignacio » Thu Apr 17, 2025 2:58 am
Seems that your initial error was due to networking issue. If you are using a proxy (either in vscode or in your setup) it might break the connection to Espressif download servers as described by the error.
Currently you use the offline installer which it seems not to include pip in the embedded python path.
Try running D:\Espressif\tools\idf-python\3.11.2\python.exe -m ensurepip to install pip in the embedded python. Check that D:\Espressif\tools\idf-python\3.11.2\python.exe -m pip --version does return the version. Test again in extension setup wizard.
