Modified AT commands
Anviori
Postby Anviori » Sun Apr 13, 2025 1:03 am
I'm using version 3.2.1.0 of ESP-AT: https://github.com/espressif/esp-at/tree/v3.2.1.0.
I see that the lib32_at_core is provided as a library, so I can't modify anything in there. Is there any way to modify the functionality of an existing AT command? Or override an existing command to perform a different action by creating a custom one with the same name?
Thank you
esp-at
Re: Modified AT commands
Postby esp-at » Mon Apr 14, 2025 3:20 am
The AT command override feature was added after 2024.3, and you will need to use version 3.3.0.0 or later.
Anviori
Postby Anviori » Mon Apr 14, 2025 3:42 am
Hi, is there a specific example you can share of how that's done/works, if you don't mind.
Also, this is for ESP32 specifically.
Just to give an example, would it be possible to modify/override the AT+RESTORE command to “restore all parameters saved in flash to factory default settings of the module.”, but avoid having it restart the device automatically afterward?
https://espressif-docs.readthedocs-host ... md-restore
Anviori
Postby Anviori » Mon Apr 14, 2025 9:24 pm
I'm having trouble find any mention of command overrides in versions >= 3.3.0.0. I can see an example of module overrides: https://github.com/espressif/esp-at/tre ... ule_config but that's not what I'm looking for.
esp-at
Postby esp-at » Thu Apr 17, 2025 3:28 am
you can see this example:
https://github.com/espressif/esp-at/blo ... stom_cmd.c
Just instead `+TEST` with `+RESTORE`, then AT will execute your AT+RESTORE command.
btw, if you don't restart the module, some configurations will not effect.
About how to reset the parameters, you can extern this API, and call it in `at_exe_cmd_test()`.
void at_nvm_restore(void);
Anviori
Postby Anviori » Thu Apr 17, 2025 3:45 pm
Well, I was just using `AT+RESTORE` as an example. Are you saying that I can create a custom command called `AT+RESTORE` (a core command) and it will use that instead of the standard implementation when I call it?
esp-at
Postby esp-at » Fri Apr 25, 2025 2:15 am
yes. you can give it a try.
