Freertos task, required large stack for one ESP_LOG printout
Stipa88
Postby Stipa88 » Thu Jan 25, 2024 7:43 am
Hi.
I am creating a task. In the task function, within the for(;;) loop, I periodically print one LOG message via the ESP_LOGI function-definition.
In order for it to work, without crash and ESP reset, a stack of "1650" (stack is defined in words) size is required. 6.44kB is the task necessary? Why so many? Where is the problem?
void prvADCNewDataTask( void *);
TaskHandle_t xHandleADCNewDataTask = NULL;
void CreateADC_Task()
	ESP_LOGI(TAG, "Create_ADC_Task...");
	xTaskCreate( prvADCNewDataTask, "ADCData_Task", 1650, NULL, tskIDLE_PRIORITY + 1, &xHandleADCNewDataTask);
	ESP_LOGI(TAG, "Success Create_ADC_Task");
void prvADCNewDataTask(void * argument)
	ESP_LOGI(TAG, "ADCNewDataTask Started");
	volatile uint32_t stackHighWaterMark = 0;
	for(;;)
		vTaskDelay(100);
		stackHighWaterMark = uxTaskGetStackHighWaterMark(xHandleADCNewDataTask);
		ESP_LOGI(TAG, "Free: %u words", stackHighWaterMark);		// stackHighWaterMark = 24
Pls help. Tnx
Re: Freertos task, required large stack for one ESP_LOG printout
Postby Sprite » Thu Jan 25, 2024 9:37 am
The stack size in ESP-IDF is defined in bytes, see the note at the bottom of this chapter.
lotharyx
Postby lotharyx » Tue Apr 29, 2025 8:55 pm
Bumping this old thread because the Espressif staff response from Sprite is not helpful.
What is the stack requirement for ESP_LOGx macros? I am also encountering stack overflows caused by the ESP_LOGx calls if the stack is under 2048 (maybe less; I have not tried to determine the exact requirement).
This suggests that the library code is trying to use a stack-based buffer for its calls to _vfprintf_r (the only function named in the panic message). Is there any way to configure the size of that buffer so that tasks with logging need less stack space?
Sample panic message:
Guru Meditation Error: Core  0 panic'ed (Stack protection fault).
Detected in task "ptx_u2" at 0x4209a040
--- 0x4209a040: _vfprintf_r at /builds/idf/crosstool-NG/.build/riscv32-esp-elf/src/newlib/newlib/libc/stdio/vfprintf.c:654
Stack pointer: 0x3fcb3160
Stack bounds: 0x3fcb32a0 - 0x3fcb3690
Setting breakpoint at 0x4209a044 and returning...
--- 0x4209a044: _vfprintf_r at /builds/idf/crosstool-NG/.build/riscv32-esp-elf/src/newlib/newlib/libc/stdio/vfprintf.c:654
These messages repeat at high speed until the monitor is shut down.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
