What is the issue of connecting several esp8266 with espnow ?
engkhaledeisa
Postby engkhaledeisa » Wed Apr 30, 2025 11:42 pm
Hi is there a issue connecting several esp8266 through espnow ? Data arenot received by the receiver and I try all the solutions but nothing? Should i change to esp32
Issue with connection using Espnow between several esp8266
Hi how are you i try to use espnow to communicate between several esp8266 but sometimes it works and other times donnot that packets arenot received when i search I found it works mainly for esp32 but on esp8266 it works with limitations so what I should do or should I change project to work using esp32 ?
okay I have one master and 3 nonmster esp8266 ....when I get my hand close to proximity sensor of the first one which is the master .....data packet should sent randomly to any one of the nonmaster ....but the data already sent but didnot received by any of other then I searched and found the espnow full functional features can be accessed by esp32 but limited features on esp8266 ( please note I try to upload the connection r
Master
#define MY_ROLE ESP_NOW_ROLE_COMBO // set the role of this device: CONTROLLER, SLAVE, COMBO
#define RECEIVER_ROLE ESP_NOW_ROLE_COMBO // set the role of the receiver
/*replaceValueHere*/ #define MY_ECU 1 //ECU number
#define WIFI_CHANNEL 1
#define MACADDRESSSIZE 6 //Mac address size
#define NO_ECU 0 //No ecu with the define MY_ECU 0
#define RGBCLEARDELAY 100 //delay to be used with RGB clear ?TBD
/*replaceValueHere*/ #define AVAILABLEECU 4 //Nr of ECUs to be used
#define MAXAVAILABLEECU 10 // I think ESPNOW supports up to 10 devices
//Receivers ECUS addreses.Add all of them here.
// /*replaceValueHere*/ uint8_t receiverAddress1[] = { 0xF4, 0xCF, 0xA2, 0x5D, 0x75, 0x28 }; // this ECU MAC address ,only for example purposes
/*replaceValueHere*/ uint8_t receiverAddress2[] = { 0xAC, 0x0B, 0xFB, 0xCF, 0xC1, 0x0F }; // ECU 2
/*replaceValueHere*/ uint8_t receiverAddress3[] = { 0xAC, 0x0B, 0xFB, 0xCF, 0xD8, 0xB1 }; // ECU 3
/*replaceValueHere*/ uint8_t receiverAddress4[] = { 0xF4, 0xCF, 0xA2, 0x79, 0x23, 0x84 }; // ECU 4
// /*replaceValueHere*/ uint8_t receiverAddress4[] = { 0x4C, 0xEB, 0xD6, 0x62, 0x09, 0x54 }; // ECU 5
uint8_t receiverECU_Address[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; //Placeholder for the receiver address
uint8_t receiverArray[MAXAVAILABLEECU][MACADDRESSSIZE];
struct __attribute__((packed)) dataPacketAlone {
uint8_t LED_Token; // Token for activating ECUs
uint8_t counterExerciseData;
struct __attribute__((packed)) dataPacketPartner {
uint8_t LED_Token_Partner;
uint8_t activeECU;
uint8_t counterExercisePartner;
struct __attribute__((packed)) dataPacketSettings {
uint8_t training_NrOfEcus;
uint8_t training_trainingType;
uint8_t training_nrOfColors;
uint8_t training_counterValStop;
uint16_t training_stopTimeDuration;
uint8_t training_partnerMode_P1Color;
uint8_t training_partnerMode_P2Color;
uint32_t training_maxIntervalTime;
uint32_t training_minIntervalTime;
uint8_t winnerPartner;
//state in which the ECU can be found
enum transmissionState_en {
DATARECEIVED_en,
SENDDATA_en,
SENDINGDATA_en,
TRANSMISIONSUCCESFULL_en,
ONLYRECEIVE_en
/*replaceValueHere*/ dataPacketAlone packetAlone = { 1, 0 }; //Package of data to be sent !if not ECU1 set to 0!
transmissionState_en TransmisionStatus = DATARECEIVED_en; //Transmision Status
dataPacketSettings packetSettings;
dataPacketPartner partnerP1 = { 1, 3, 0 };
dataPacketPartner partnerP2 = { 2, 2, 0 };
uint8_t P1TOFtrigger = 0;
uint8_t P2TOFtrigger = 0;
void initReceiverAddress(void) {
// memcpy(&receiverArray[0], NOECU, 6); //no ECU is allowed to be on 0 position
// memcpy(&receiverArray[1], receiverAddress1, 6); //This is my ECU position doesn't need to be filed.
switch (training_SelectNrOfECUs) {
case 1:
memcpy(&receiverArray[2], receiverAddress2, 6);
esp_now_add_peer(receiverAddress2, RECEIVER_ROLE, WIFI_CHANNEL, NULL, 0);
break;
case 2:
memcpy(&receiverArray[3], receiverAddress3, 6);
esp_now_add_peer(receiverAddress3, RECEIVER_ROLE, WIFI_CHANNEL, NULL, 0);
break;
case 3:
memcpy(&receiverArray[4], receiverAddress4, 6);
esp_now_add_peer(receiverAddress4, RECEIVER_ROLE, WIFI_CHANNEL, NULL, 0);
break;
case 4:
//to add
//to add
break;
//and so on until MAXAVAILABLEECU
void initESPNOWcomm(void) {
WiFi.mode(WIFI_STA);
WiFi.disconnect(); // we do not want to connect to a WiFi network
if (esp_now_init() != 0) {
Serial.println("ESP-NOW initialization failed");
return;
Serial.print("ESP Board MAC Address: ");
Serial.println(WiFi.macAddress());
esp_now_set_self_role(MY_ROLE);
esp_now_register_send_cb(transmissionComplete); // this function will get called once all data is sent
esp_now_register_recv_cb(dataReceived); // this function will get called whenever we receive data
// initReceiverAddress();
Not Master
`#define NEWTRAININGMAXTIME 4`
`#define MY_ROLE ESP_NOW_ROLE_COMBO        // set the role of this device: CONTROLLER, SLAVE, COMBO`
`#define RECEIVER_ROLE ESP_NOW_ROLE_COMBO  // set the role of the receiver`
`/*replaceValueHere*/ #define MY_ECU 2     //ECU number`
`#define WIFI_CHANNEL 1`
`#define MACADDRESSSIZE 6                       //Mac address size`
`#define NO_ECU 0                               //No ecu with the define MY_ECU 0`
`#define RGBCLEARDELAY 100                      //delay to be used with RGB clear ?TBD`
  `/*replaceValueHere*/ #define AVAILABLEECU 4  //Nr of ECUs to be used`
`#define MAXAVAILABLEECU 10                     // I think ESPNOW supports up to 10 devices`
  `//Receivers ECUS addreses.Add all of them here.`
  `/*replaceValueHere*/ uint8_t receiverAddress1[] = { 0xF4, 0xCF, 0xA2, 0x5D, 0x75, 0x28 };  //  this ECU MAC address ,only for example purposes`
`// /*replaceValueHere*/ uint8_t receiverAddress2[] = { 0xAC, 0x0B, 0xFB, 0xCF, 0xC1, 0x0F };  //  ECU 2`
`/*replaceValueHere*/ uint8_t receiverAddress3[] = { 0xAC, 0x0B, 0xFB, 0xCF, 0xD8, 0xB1 };    //  ECU 3`
`/*replaceValueHere*/ uint8_t receiverAddress4[] = { 0xF4, 0xCF, 0xA2, 0x79, 0x23, 0x84 };    //  ECU 4`
`// /*replaceValueHere*/ uint8_t receiverAddress5[] = { 0x4C, 0xEB, 0xD6, 0x62, 0x09, 0x54 };    //  ECU 5`
`uint8_t receiverECU_Address[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };  //Placeholder for the receiver address`
`uint8_t receiverArray[MAXAVAILABLEECU][MACADDRESSSIZE];`
`struct __attribute__((packed)) dataPacketAlone {`
  `uint8_t LED_Token;  // Token for activating ECUs`
  `uint8_t counterExerciseData;`
`struct __attribute__((packed)) dataPacketPartner {`
  `uint8_t LED_Token_Partner;`
  `uint8_t activeECU;`
  `uint8_t counterExercisePartner;`
`struct __attribute__((packed)) dataPacketSettings {`
  `uint8_t training_NrOfEcus;`
  `uint8_t training_trainingType;`
  `uint8_t training_nrOfColors;`
  `uint8_t training_counterValStop;`
  `uint16_t training_stopTimeDuration;`
  `uint8_t training_partnerMode_P1Color;`
  `uint8_t training_partnerMode_P2Color;`
  `uint32_t training_maxIntervalTime;`
  `uint32_t training_minIntervalTime;`
  `uint8_t winnerPartner;`
`//state in which the ECU can be found`
`enum transmissionState_en {`
  `DATARECEIVED_en,`
  `SENDDATA_en,`
  `SENDINGDATA_en,`
  `TRANSMISIONSUCCESFULL_en,`
  `ONLYRECEIVE_en`
`/*replaceValueHere*/ dataPacketAlone packetAlone = { 1, 0 };  //Package of data to be sent !if not ECU1 set to 0!`
`dataPacketSettings packetSettings = { 0 };`
`dataPacketPartner partnerLocal = { 2, 2, 0 };`
`transmissionState_en TransmisionStatus = DATARECEIVED_en;  //Transmision Status`
`void initReceiverAddress(void) {`
  `switch (packetSettings.training_NrOfEcus) {`
`case 2:`
`memcpy(&receiverArray[3], receiverAddress3, 6);`
`esp_now_add_peer(receiverAddress3, RECEIVER_ROLE, WIFI_CHANNEL, NULL, 0);`
`break;`
`case 3:`
`memcpy(&receiverArray[4], receiverAddress4, 6);`
`esp_now_add_peer(receiverAddress4, RECEIVER_ROLE, WIFI_CHANNEL, NULL, 0);`
`break;`
`case 4:`
`//to add 5`
`//to add 5`
`break;`
  `//and so on until MAXAVAILABLEECU`
`void initESPNOWcomm(void) {`
  `WiFi.mode(WIFI_STA);`
  `WiFi.disconnect();  // we do not want to connect to a WiFi network`
  `if (esp_now_init() != 0) {`
`Serial.println("ESP-NOW initialization failed");`
`return;`
  `Serial.print("ESP Board MAC Address:  ");`
  `Serial.println(WiFi.macAddress());`
  `esp_now_set_self_role(MY_ROLE);`
  `esp_now_register_send_cb(transmissionComplete);  // this function will get called once all data is sent`
  `esp_now_register_recv_cb(dataReceived);          // this function will get called whenever we receive data`
  `/*replaceValueHere*/                                                       //add peers here or modify the reciverAddress to the right ECUS`
  `esp_now_add_peer(receiverAddress1, RECEIVER_ROLE, WIFI_CHANNEL, NULL, 0);  // this is the master and we need to add it before everyone else because the commands come from it.`
  `memcpy(&receiverArray[1], receiverAddress1, 6);`
Users browsing this forum: Applebot, YisouSpider and 9 guests
