Cannot read properties of undefined (reading 'fsPath')
username
Postby username » Tue May 06, 2025 4:14 pm
Espressif VS Code Extension Version: 1.10.0
Mine got updated to v1.10.0 and things got messed up creating a new project.
I now get hit with a popup when creating a new project.
Screenshot 2025-05-06 110700.png (7.3 KiB) Viewed 5078 times
I preformed a clean uninstall, and tried reinstalling a couple times now but still gives me the same error.
itsjagnezi
Re: Cannot read properties of undefined (reading 'fsPath')
Postby itsjagnezi » Tue May 06, 2025 11:10 pm
I'm new here, but I'm having the same issue. I don't know how to fix it for now... I'll try to install another version of ESP-IDF
username
Postby username » Wed May 07, 2025 2:24 am
I went to the previous version of Espressif VS Code Extension, and everything worked.
redgeca
Postby redgeca » Sat May 10, 2025 1:43 pm
Got the same issue. Reverting to extension 1.9.x solves the problem
redplane
Postby redplane » Sat May 10, 2025 2:06 pm
Same here.
I re-installed the old version (1.9.1) and things worked.
Mahmoud
Postby Mahmoud » Sun May 11, 2025 2:54 pm
same
GuerreroMX
Postby GuerreroMX » Mon May 12, 2025 9:32 am
Indeed, reverting to version 1.9.1 of the ESp-IDF extension fixes the problem.
bignacio
Postby bignacio » Tue May 13, 2025 8:56 am
This is a known issue and it was fixed in GitHub master already with Pull Request https://github.com/espressif/vscode-esp ... /pull/1538
You can test the current master installer from https://nightly.link/espressif/vscode-e ... n.vsix.zip
You can use this VSIX to test the current github master of the extension by pressing F1 or click menu View -> Command Palette..., type Install from VSIX and then select the previously downloaded .vsix file to install the extension.
YanceyChiew
Postby YanceyChiew » Sat May 24, 2025 7:19 pm
This may be related to the fact that there is no open file/directory in vscode. Although esp-idf extension does not respect the currently opened directory when creating a new project, in order to avoid this error, you should open a directory first.
13565298285@163.com
Postby 13565298285@163.com » Mon Jun 02, 2025 6:47 am
新建一个空白文件夹,然后打开新建的空白文件夹,再新建工程就可以了
Users browsing this forum: Baidu [Spider], Bing [Bot] and 3 guests
