eMMC write speed test
JPMJPM
Postby JPMJPM » Sun May 11, 2025 10:27 am
HI,
I have tested the write speed of a SAMSUNG eMMC with two different sketchs. The writing speed of the second
sketch is much lower.
Sketch 1)
https://github.com/espressif/arduino-es ... C_Test.ino
with SD_MMC.setPins(3, 5, 1, 13, 7, 6);
with SD_MMC.begin("/sdcard", false, false, 20000, 5); // 4-bit line mode and CLK = 20 MHz
Write speed --> 1048576 bytes written for 285 ms
Sketch 2) The following sketch (4-bit line mode and CLK = 20 MHz)
Write speed --> 1048576 bytes written for 1170 ms
Can someone tell me what I did wrong in the second sketch ?.
// Sketch 2
#include <string.h>
#include <sys/unistd.h>
#include <sys/stat.h>
#include "esp_vfs_fat.h"
#include "sdmmc_cmd.h"
#include "driver/sdmmc_host.h"
#include "FS.h"
#define MOUNT_POINT "/eMMC"
void setup(){
  Serial.begin(115200);
  Serial.printf("ESP-IDF version = %s\n", esp_get_idf_version());
  esp_vfs_fat_sdmmc_mount_config_t mount_config = {
    .format_if_mount_failed = true,
    .max_files = 5,
    .allocation_unit_size = 16 * 1024
  sdmmc_card_t *card = NULL;
  const char mount_point[] = MOUNT_POINT;
  sdmmc_host_t host = SDMMC_HOST_DEFAULT();
  host.max_freq_khz = 20000;
  //host.max_freq_khz = SDMMC_FREQ_HIGHSPEED;
  //host.flags &= ~SDMMC_HOST_FLAG_DDR;
  sdmmc_slot_config_t slot_config = {
        .cd = SDMMC_SLOT_NO_CD,
        .wp = SDMMC_SLOT_NO_WP,
  slot_config.width = 4;
  slot_config.clk = GPIO_NUM_3;
  slot_config.cmd = GPIO_NUM_5;
  slot_config.d0 = GPIO_NUM_1;
  slot_config.d1 = GPIO_NUM_13;
  slot_config.d2 = GPIO_NUM_7;
  slot_config.d3 = GPIO_NUM_6;
  esp_err_t ret = esp_vfs_fat_sdmmc_mount(mount_point, &host, &slot_config, &mount_config, &card);
  if (ret != ESP_OK) {
    Serial.println("Failed to mount filesystem.");
    return;
  Serial.println("Filesystem mounted");
  ///////////////// eMMC write speed test
  int i;
  static char buf[512];
  for (i = 0; i < 512; i++) {
    buf[i] = 'A';
  const char *file_test_write_speed = MOUNT_POINT"/test_write_speed.txt";
  FILE *fi = fopen(file_test_write_speed, "w");
  uint32_t start = millis();
  uint32_t end = start;
  for (i = 0; i < 2048; i++) {
    fwrite(buf, 1, 512, fi);
  end = millis() - start;
  Serial.printf("%u bytes written for %lu ms\n", 2048 * 512, end);
  fclose(fi);
  // All done, unmount partition and disable SDMMC peripheral
  esp_vfs_fat_sdcard_unmount(mount_point, card);
  Serial.println("Card unmounted");
void loop(){
  delay(1);
lbernstone
Re: eMMC write speed test
Postby lbernstone » Sun May 11, 2025 5:20 pm
You are writing single bytes. Disk writes will always be fastest if you match the write size to the sector/block size- 512 bytes in the case of an SD.
JPMJPM
Postby JPMJPM » Mon May 12, 2025 6:17 am
I think fwrite(buf, 1, 512, fi) write an array of 512 bytes, Isn't that right ?.
Is there another way to do this ?.
Regards.
Users browsing this forum: PerplexityBot, Qwantbot and 1 guest
