[Resolved] H264 decode on ESP32-S4
digitalLumberjack
Postby digitalLumberjack » Sun May 11, 2025 1:03 pm
Hello I think someone may have encountered the same problem as described on esp32 h264 module here :
https://github.com/espressif/esp-h264-c ... t/issues/5
I'm trying to decode H264 video with ESP32-P4.
I encode a video this way :
ffmpeg -y -i gundam.original.mp4 -c:v libx264 -profile:v baseline -preset veryslow -tune fastdecode -vf "format=yuv420p, scale=320:240" -x264opts slices=1 -an gundam.h264
Having this ouput:
[libx264 @ 0x5d78f9973a40] profile Constrained Baseline, level 2.2, 4:2:0, 8-bit
Output #0, h264, to 'gundam.h264':
  Metadata:
    major_brand     : mp42
    minor_version   : 0
    compatible_brands: isommp42
    encoder         : Lavf61.1.100
  Stream #0:0(und): Video: h264, yuv420p(tv, bt709, progressive), 320x240 [SAR 4:3 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbn (default)
      Metadata:
        creation_time   : 2020-02-05T18:42:37.000000Z
        handler_name    : ISO Media file produced by Google Inc. Created on: 02/05/2020.
        vendor_id       : [0][0][0][0]
        encoder         : Lavc61.3.100 libx264
      Side data:
        cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A
[out#0/h264 @ 0x5d78f9975140] video:2724KiB audio:0KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 0.000000%
frame= 2158 fps=326 q=-1.0 Lsize=    2724KiB time=00:01:30.00 bitrate= 247.9kbits/s speed=13.6x
We can see the video is `Stream #0:0(und): Video: h264, yuv420p(tv, bt709, progressive), 320x240 [SAR 4:3 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbn (default)` it seems to be what the H264 decoder is excepting.
When I decode the H264 stream with ESP32P4 on a project that quite simple, based on the testing app :
esp_h264_err_t H264Engine::playVideo(uint8_t * file, uint16_t size) {
    esp_h264_dec_in_frame_t in_frame;
    esp_h264_dec_out_frame_t out_frame;
    esp_h264_err_t ret = ESP_H264_ERR_FAIL;
    esp_h264_dec_handle_t dec = nullptr;
    esp_h264_dec_cfg_sw_t cfg;
    cfg.pic_type = ESP_H264_RAW_FMT_I420;
    int frames_decoded = 0;
    ret = esp_h264_dec_sw_new(&cfg, &dec);
    if (ret != ESP_H264_ERR_OK) {
        printf("new failed. line %d \n", __LINE__);
        goto _single_exit_;
    ret = esp_h264_dec_open(dec);
    ESP_LOGI("H264", "esp_h264_dec_open");
        printf("open failed .line %d \n", __LINE__);
        goto _single_exit_;
    in_frame.raw_data.buffer = file;
    in_frame.raw_data.len = size;
    esp_h264_dec_param_sw_handle_t dec_param;
    esp_h264_resolution_t res;
    while (1) {
        if (in_frame.raw_data.len <= 0) {
            break;
        ESP_LOGI("H264", "decoding");
        ret = esp_h264_dec_process(dec, &in_frame, &out_frame);
        esp_h264_dec_sw_get_param_hd(dec, &dec_param);
        esp_h264_dec_get_resolution(dec_param, &res);
        ESP_LOGI("H264", "res = %dx%d", res.width, res.height);
        in_frame.raw_data.buffer += in_frame.consume;
        in_frame.raw_data.len -= in_frame.consume;
        ESP_LOGI("H264", "consumed %d, now at %d",  in_frame.consume, in_frame.raw_data.buffer);
        ESP_LOGI("H264", "input frame dts: %d, pts: %d", in_frame.dts, in_frame.pts);
        ESP_LOGI("H264", "decoded frames %d", frames_decoded++);
        if (ret == ESP_H264_ERR_OK) {
            ESP_LOGI("H264", "frame decoded size: %d, dts: %d, pts: %d", out_frame.out_size, out_frame.dts, out_frame.pts);
        } else {
            printf("process failed. ret %d line %d \n", ret, __LINE__);
            goto _single_exit_;
        vTaskDelay(1);
    _single_exit_:
        ESP_LOGI("H264", "exiting");
        esp_h264_dec_close(dec);
        esp_h264_dec_del(dec);
    return ret;
I can decode up to 40 frames but I then I have:
I (2596) H264: decoded 38
I (2598) H264: frame decoded size: 115200, dts: 1341241836, pts: 1073952316
I (2607) H264: decoding
I (2619) H264: res = 320x240
I (2619) H264: consumed 551, now at 1074014023
I (2619) H264: input frame dts: 1341241836, pts: 1073952316
I (2620) H264: decoded 39
I (2623) H264: frame decoded size: 115200, dts: 1341241836, pts: 1073952316
I (2631) H264: decoding
E (2640) H264_DEC: Decode macroblock layer error(210).
E (2640) H264_DEC: Decode slice data error.
E (2643) H264_DEC.SW: Error in decoding
I (2646) H264: res = 320x240
I (2649) H264: consumed 377, now at 1074014400
I (2653) H264: input frame dts: 1341241836, pts: 1073952316
I (2659) H264: decoded 40
process failed. ret -1 line 63
I (2664) H264: exiting
I tried with many different videos, many encoder options, but it seems I cannot achieve a entire decoding.
Is there any standard ffmpeg configuration you can provide if it's encoding configuration causing the issue ?
Any other ideas ?
### Project release version
component 1.1.1 on idf master 1c468f68259065ef51afd114605d9122f13d9d72
Last edited by digitalLumberjack on Mon May 12, 2025 5:06 pm, edited 1 time in total.
digitalLumberjack
Re: H264 decode on ESP32-S4
Postby digitalLumberjack » Mon May 12, 2025 5:05 pm
Users browsing this forum: ChatGPT-User, Google [Bot], PetalBot and 1 guest
