Dear,
I would like to have example code which can be used with tuya application or Smart Life: https://github.com/espressif/arduino-es ... ateway.ino
I want to create a zigbee gateway and devices zigbee
Thank you.
esp32-C6 zigbee tuya smart life
lbernstone
Re: esp32-C6 zigbee tuya smart life
Tuya != zigbee. Tuya uses an encrypted mqtt connection. Older models may be able to be jailbroken, but newer models would need access to the chip (through uart) to reprogram.
As device : https://www.aliexpress.com/item/1005007694554158.html
is detected with this code: https://github.com/espressif/arduino-es ... n_Networks
I thought tuya was doing the same thing as Smart Life application
lbernstone
Users browsing this forum: PerplexityBot, Qwantbot and 1 guest
