esp32-c6 does not connected to strongest ssid in Multi AP environment
grooves
Postby grooves » Wed May 14, 2025 12:57 pm
Hi folk,
I have a strange problem to connect to ssid with strongest rssi when the same ssid is visible with different rssi's or/and different channels, like this:
I (3170) scan: SSID MY Wifi
I (3170) scan: RSSI -67
I (3180) scan: BSSID 84:39:8f:fe:86:db
I (3180) scan: Authmode WIFI_AUTH_WPA2_PSK
I (3180) scan: Pairwise Cipher WIFI_CIPHER_TYPE_CCMP
I (3190) scan: Group Cipher WIFI_CIPHER_TYPE_CCMP
I (3190) scan: Channel 11
I (3270) scan: SSID MY Wifi
I (3270) scan: RSSI -77
I (3280) scan: BSSID 84:39:8f:32:cc:9b
I (3280) scan: Authmode WIFI_AUTH_WPA2_PSK
I (3280) scan: Pairwise Cipher WIFI_CIPHER_TYPE_CCMP
I (3290) scan: Group Cipher WIFI_CIPHER_TYPE_CCMP
I (3290) scan: Channel 6
I (3540) scan: SSID MY Wifi
I (3550) scan: RSSI -79
I (3550) scan: BSSID 84:39:8f:fa:ae:bb
I (3550) scan: Authmode WIFI_AUTH_WPA2_PSK
I (3560) scan: Pairwise Cipher WIFI_CIPHER_TYPE_CCMP
I (3560) scan: Group Cipher WIFI_CIPHER_TYPE_CCMP
I (3570) scan: Channel 11
via forced bssid_set = 1 and given bssid I can connect always to 84:39:8f:32:cc:9b and 84:39:8f:fa:ae:bb,
but never to 84:39:8f:fe:86:db, which is the strongest AP.
I use simple esp-idf example: wifi getting_started station, modified with bssid stuff.
I get error reason: 2 toggling with 205, extend log shows something wrong with authorization
I (52214) wifi:(connect)dot11_authmode:0x3, pairwise_cipher:0x3, group_cipher:0x3
I (52214) wifi:state: init -> auth (0xb0)
I (53224) wifi:state: auth -> init (0x200)
I (53234) wifi:new:<11,0>, old:<11,0>, ap:<255,255>, sta:<11,0>, prof:1, snd_ch_cfg:0x0
any hints ?
Thanks,
Mike
nopnop2002
Contact:
Re: esp32-c6 does not connected to strongest ssid in Multi AP environment
Postby nopnop2002 » Fri May 16, 2025 3:07 am
What happens if you change ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD to something other than WIFI_AUTH_WPA2_PSK?
You can change this in menuconfig.
#if CONFIG_ESP_WIFI_AUTH_OPEN
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_OPEN
#elif CONFIG_ESP_WIFI_AUTH_WEP
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WEP
#elif CONFIG_ESP_WIFI_AUTH_WPA_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WAPI_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WAPI_PSK
#endif
grooves
Postby grooves » Mon May 19, 2025 9:57 am
I tried all combinations,
no changes :(
Regards,
Mike
grooves
Postby grooves » Mon May 19, 2025 2:21 pm
I disabled password at AP,
and set wifi_config to:
wifi_config_t wifi_config = {
.sta = {
.ssid = "MY Wifi",
.password = "",
.threshold.authmode = WIFI_AUTH_OPEN,
.bssid_set = 0,
get the same error:
wifi:new:<6,0>, old:<9,0>, ap:<255,255>, sta:<6,0>, prof:1, snd_ch_cfg:0x0
I (59210) wifi:state: init -> auth (0xb0)
I (60230) wifi:state: auth -> init (0x200)
I (60240) wifi:new:<6,0>, old:<6,0>, ap:<255,255>, sta:<6,0>, prof:1, snd_ch_cfg:0x0
I (60240) wifi station: WIFI_EVENT_STA_DISCONNECTED: reason: 2
pretty weird, because there is no authorization anymore
Cheers,
Mike
nopnop2002
Contact:
Postby nopnop2002 » Mon May 19, 2025 10:41 pm
What happens if You turn off these two WiFi routers?
If multiple WiFi routers are transmitting signals in a small space, interference can occur.
I have three Wi-Fi routers in my room, each with a different SSID.
When I add a fourth one with a different SSID it is not recognized.
grooves
Postby grooves » Tue May 20, 2025 12:00 pm
the APs are not under our control, it is an external IT company,
but I could fix it by adding one line before esp wifi start:
ESP_ERROR_CHECK(esp_wifi_config_11b_rate(WIFI_IF_STA, true));
ESP_ERROR_CHECK(esp_wifi_start());
my theorie is:
APs do not support old 11B protocol anymore, but ESP32 starts with it and wants to negociate password in that mode.
the line above disables 11B protocol in ESP32, and connection starts immediatly
Cheers,
Mike
