Increase the WIFI_MESH MTU packet size so I can send larger MQTT messages
MichaelS
Postby MichaelS » Mon May 26, 2025 7:17 am
With the ESP-32 using IDF, is it possible to increase the WIFI_MESH MTU packet size so I can send larger MQTT messages across the WIFI_MESH network.
I thought (or hoped) the ESP library would break down the large MQTT packets for transmission across the WIFI_MESH network and they would be re-assembled in the MESH_ROOT for sending on to the Broker but this seems not to be the case. I am using ESP-IDF 5.3.1
ahsrabrifat
Re: Increase the WIFI_MESH MTU packet size so I can send larger MQTT messages
Postby ahsrabrifat » Mon May 26, 2025 8:17 am
Unfortunately, increasing the MTU in ESP-MESH is not currently supported:
It is constrained by the underlying UDP/IPv4 and 802.11 frame limits.
You may see config options like CONFIG_MESH_MTU in older SDKs, but they don’t allow exceeding ~1472 bytes due to hardware/firmware limitations.
Users browsing this forum: trendictionbot and 6 guests
