Define Matter PhaseList in Operational State cluster of Dish Washer Endpoint
tomasmcguinness
Postby tomasmcguinness » Fri Jun 13, 2025 3:14 pm
I am trying to understand how to configure the Operational State cluster on a Dishwasher Endpoint.
I can see that an operations state cluster is created when the dish_washer::add method is called
operational_state::create(endpoint, &(config->operational_state), CLUSTER_FLAG_SERVER);
I have tried to fetch the cluster and attribute
cluster_t *operational_state_cluster = cluster::get(endpoint, OperationalState::Id);
esp_matter::attribute_t *phase_list_attr = esp_matter::attribute::get(operational_state_cluster, chip::app::Clusters::OperationalState::Attributes::PhaseList::Id);
but I'm uncertain how to create and set the phase list.
I tried this:
uint8_t phase_list[] = { 0x00, 0x01, 0x02 };
esp_matter::attribute::set_val(phase_list_attr, &phase_val);
but that results in this error:
esp_matter_core: set_val(1098): Attribute is not managed by esp matter data model
The phase list attribute is also supposed to be strings, but I don't know how to use the uint8_t type with string values.
There don't appear to be any examples of this. Can anyone help?
tomasmcguinness
Re: Define Matter PhaseList in Operational State cluster of Dish Washer Endpoint
Postby tomasmcguinness » Mon Jun 16, 2025 4:14 pm
I made some progress with this.
I created an implementation of the Delegate, as described in the Matter SDK. This means that the Phase List and Operational Status attributes can be read successfully.
However, when I try to sent a Start command, I get an error: 0x81 Unsupported_Command.
tomasmcguinness
Postby tomasmcguinness » Tue Jun 17, 2025 10:55 am
To resolve this, I needed to add the commands to the cluster. I think that's because the commands are optional.
esp_matter::cluster_t *operational_state_cluster = esp_matter::cluster::get(endpoint, chip::app::Clusters::OperationalState::Id);
esp_matter::cluster::operational_state::command::create_start(operational_state_cluster);
esp_matter::cluster::operational_state::command::create_stop(operational_state_cluster);
esp_matter::cluster::operational_state::command::create_pause(operational_state_cluster);
esp_matter::cluster::operational_state::command::create_resume(operational_state_cluster);
Once I made that change, the various callbacks get invoked as expected.
Users browsing this forum: PerplexityBot and 2 guests
