Compiling error
ted123
Compiling error
Postby ted123 » Mon Jun 23, 2025 7:57 pm
Hi I'm trying to run this program but I have a compiling error.
How to fix that ?
exit status 1
'ledcSetup' was not declared in this scope
#include <Arduino.h>
#include <math.h>
const int pwmPin = 16;      // Example PWM pin
const int pwmFrequency = 5000; // Example frequency
const int pwmResolution = 8;  // Example resolution (0-255)
const int ledcChannel = 0; // Example channel
const float amp = 127.5; // Half of the max value (255/2)
const float stp = 0.1;  // Step size for the sine wave
float i = 0;
void setup() {
  ledcSetup(ledcChannel, pwmFrequency, pwmResolution);
  ledcAttachPin(pwmPin, ledcChannel);
void loop() {
  int dutyCycle = (int)(amp + amp * sin(stp * i)); // Calculate the duty cycle
  ledcWrite(ledcChannel, dutyCycle);             // Write the duty cycle
  i += 1; // Increment the iterator
  delay(10); // Add a small delay to control the speed
lbernstone
Re: Compiling error
Postby lbernstone » Tue Jun 24, 2025 3:57 am
ledcSetup was from an older version of the API.
Doco
examples
ted123
Re: Compiling error
Postby ted123 » Tue Jun 24, 2025 6:25 am
And a new version is ?
lbernstone
Re: Compiling error
Postby lbernstone » Wed Jun 25, 2025 3:28 pm
Current stable is v3.2.0
lsdlsd88
Re: Compiling error
Postby lsdlsd88 » Fri Jun 27, 2025 2:03 pm
easiest way is install last 2.x version on esp32 board manager
RandomInternetGuy
Re: Compiling error
Postby RandomInternetGuy » Thu Jul 31, 2025 5:41 pm
Best way is to modernize the code so you're not always having to find outdated versions of things.
ledCsetup's demise was documented long ago.
https://docs.espressif.com/projects/ard ... o_3.0.html
horace99
Re: Compiling error
Postby horace99 » Fri Aug 01, 2025 5:28 am
have a look at the section on LEDC in https://docs.espressif.com/projects/ard ... o_3.0.html which gives details the new APIs
Users browsing this forum: Google [Bot] and 3 guests
