Seeking Guidance: Choosing a WiFi Board for RS-485 Sensor Integration and MQTT Cloud Communication.
Jazz_J
Postby Jazz_J » Sun Jun 29, 2025 3:40 pm
Hello everyone,
I'm embarking on a new IoT project and am looking for some experienced insights and guidance. My goal is to read data from various sensors using RS-485 communication and then transmit this data to a cloud platform via MQTT. I'm currently evaluating different WiFi boards and would greatly appreciate advice on selecting the most suitable one for this application.
I'm particularly keen to understand the following:
1. Best WiFi Board for RS-485 to MQTT Cloud Communication:
* What are the recommended WiFi development boards or industrial gateways that are well-suited for projects involving RS-485 communication and MQTT cloud integration?
* Are there specific features or specifications I should prioritize when making this selection (e.g., processing power, memory, security features, ease of programming/libraries)?
* Any personal experiences with particular boards in similar setups would be highly valuable.
2. Understanding RS-485 Communication:
* Could someone please provide a clear explanation of how RS-485 communication works at a fundamental level? I'm particularly interested in:
* The concept of differential signaling and its advantages.
* The master-slave architecture typically used.
* The significance of termination resistors and biasing.
* Common protocols built on RS-485 (e.g., Modbus RTU).
* What are the common pitfalls or challenges encountered when working with RS-485, especially in terms of wiring, noise, and addressing?
3. Implementing RS-485 Communication:
* When connecting an RS-485 device to a microcontroller (like an ESP32 or similar), what are the essential hardware components needed?
* Could you share general steps or best practices for establishing communication with an RS-485 sensor from a microcontroller? This would include:
* Pin connections (A, B, DE/RE).
* Basic code structure for sending commands and receiving responses.
* Handling data parsing from RS-485 sensors (especially if using Modbus RTU).
4. Sending Data to Cloud using MQTT:
* Once I have the sensor data from RS-485, what are the recommended steps and libraries for transmitting this data to a cloud MQTT broker (e.g., AWS IoT)?
* How can I structure my MQTT topics effectively for different sensors and data types?
* What are important considerations for ensuring data reliability and security when using MQTT (e.g., QoS levels, authentication, encryption)?
* Are there any specific libraries or frameworks that simplify MQTT implementation on the recommended WiFi boards?
I understand that AI tools can provide information, but the nuanced perspectives and practical advice from individuals who have hands-on experience are truly invaluable for learning and troubleshooting.
Thank you in advance for your time and expertise. I look forward to learning from your collective wisdom!
Best regards,
Jazz
Re: Seeking Guidance: Choosing a WiFi Board for RS-485 Sensor Integration and MQTT Cloud Communication.
Postby Sprite » Mon Jun 30, 2025 2:00 am
That is a whole bunch of questions, a fair bit very open; someone would need to write a novel to answer all those. Most of them, you can find answers to on the Internet (or asking AI, if you really think you need to). How's about you post what you think are the correct answers first and the bits you're unsure of, and we'll correct your assumptions where wrong?
Jazz_J
Postby Jazz_J » Mon Jun 30, 2025 4:21 am
Hi Everyone
Thanks for your response.I thought asking an experienced person is better than asking an AI.So I can learn real-time experience what they have gone through and how did they solved the issue.Anyway can you help me with choosing a wifi board.
MicroController
Postby MicroController » Mon Jun 30, 2025 2:02 pm
All the ESP32 variants (except the 'bare' ESP32-P4 (no WiFi)), i.e. ESP32, ESP32-C2, ESP32-C3, ESP32-S2, ESP32-S3, will happily do RS485 and MQTT over WiFi. Processing power and memory shouldn't be an issue with any of them for this menial task. Security features should be identical between all of them. And programming would happen in C/C++ via ESP-IDF or Arduino, using the same drivers/libraries for all of them. If you want to use Micropython or the like, you may want to have a little more RAM, so maybe prefer the C3 over the C2 and the S3 over the S2. 2MB of flash will probably do (though OTA updates may not be possible (requires at least 2x the application size)), 4MB should be sufficient in any case, 8MB may already be overkill.
Jazz_J
Postby Jazz_J » Mon Jun 30, 2025 2:21 pm
Hi Everyone
Thanks for your kindly response.So i need to add an another recruitment I'm going to use 4-20mA.So I need to use resistor and convert it into voltage and read it in ADC.I'm going to connect 8 devices So suggest me a board that ADC is so accurate with 8 ADC pins and also I need to connect RS-485 to TTL converter in that board.So can you suggest me which is suitable for my project.
MicroController
Postby MicroController » Tue Jul 01, 2025 12:41 pm
How "accurate" of an ADC do you need? At what sampling frequency?
You can look into the internal ADCs (not super-accurate), into using external ADCs (ADS1115,...), or into an external current-to-voltage or current-to-I2C converter module.
Jazz_J
Postby Jazz_J » Tue Jul 01, 2025 3:17 pm
Hi
Thanks for your kindly response.I need an ADC with at least 12-bit resolution, preferably 16-bit for higher accuracy, since I'm measuring small sensor signals in the millivolt range.The sampling rate doesn't need to be very high around 100–500 samples per second is sufficient for my application.
I'm considering using an external ADC like the ADS1115, which gives good resolution and has an I2C interface.And also I'm looking for cost efficient.
Users browsing this forum: Barkrowler, Bytespider, Google [Bot], Perplexity-User, PerplexityBot and 2 guests
