ULP linker Issues with Folder Structure
gabika
Postby gabika » Fri Jul 11, 2025 6:27 pm
Hi all,
I’m working with ESP32-S3 and using ULP RISC-V. I'm using PlatformIO (which uses idf.py). I've encountered a couple of issues in the linker stage, which I cannot find any documentation on.
ulp_main.h Not Generated Unless ULP Source is Outside src/:
My project layout uses a src/ folder for all code. When I place ulp_main.c under src/ulp/ and define the source like this:
set(ulp_sources "ulp/ulp_main.c")
I get: fatal error: ulp_main.h: No such file or directory
I also tried placing ulp_main.c in include/ulp/ (outside src/) and referencing with:
set(ulp_sources "../include/ulp/ulp_main.c")
Still fails with the same error, as the .h file is never generated.
Only when I place ulp_main.c in a sibling folder named ulp/ (next to src/) and reference it as:
set(ulp_sources "../ulp/ulp_main.c")
ulp_main.h get generated and included properly.
This seems related to how
ulp_embed_binary()
treats paths. Is this a known constraint? Any way to put ulp/ inside src/ as I see in all the examples? What am I missing?
Another issue I am encountering is Link Errors When Calling Code from src/ subfolders in ULP:
I have some subfolders under src/ for implementing the sensors I am using. for example BPW34.
I want to call those function from ulp_main.c. When I
#include "../src/bpw34/bpw34.h"
inside ulp_main.c, compilation works, but I get undefined reference to adc_to_temperature
This is my src/CMakeLists.txt:
idf_component_register(SRCS
    "lora_remote.cpp" "lora_common.cpp"
    "lora/ra01s.c" "lora_receiver.cpp"
    "oled/ssd1306.c" "oled/ssd1306_i2c_new.c"
    "hdc2010/hdc2010.c" "bpw34/bpw34.c"
    INCLUDE_DIRS "." "lora" "oled" "hdc2010" "bpw34"
    REQUIRES soc nvs_flash ulp driver esp_adc)
# ULP build integration (must come AFTER idf_component_register)
set(ulp_app_name ulp_main)
set(ulp_exp_dep_srcs "lora_remote.cpp")
ulp_embed_binary(${ulp_app_name} "${ulp_sources}" "${ulp_exp_dep_srcs}")
Is it possible to call my c file's function in src/ subfolders from ULP main function?
Thank you!
MicroController
Re: ULP linker Issues with Folder Structure
Postby MicroController » Fri Jul 11, 2025 8:36 pm
Can you successfully build one of the RISC-V ULP examples?
Of course(?), when specifying the C source files to be built for the ULP, you have to specify all the source files you want to be compiled and linked into the ULP code.
gabika
Postby gabika » Sat Jul 12, 2025 6:05 pm
What do you mean by specifying the C source files? isn't my src/CMakeLists.txt looks fine?
# ULP build integration (MUST come AFTER idf_component_register)
Regarding the ULP structure - I am checking by building RISC-V ULP examples and reporting back! thank you
MicroController
Postby MicroController » Sat Jul 12, 2025 9:24 pm
This:
gabika
Postby gabika » Sun Jul 13, 2025 8:35 am
So I tried both:
set(ulp_sources "../ulp/ulp_main.c bpw34/bpw34.c")
and
set(ulp_sources "../ulp/ulp_main.c" "bpw34/bpw34.c")
While the following is:
And it seems to keep the error:
/Users/xxx/.platformio/packages/toolchain-riscv32-esp/bin/../lib/gcc/riscv32-esp-elf/14.2.0/../../../../riscv32-esp-elf/bin/ld: CMakeFiles/ulp_main.dir/Users/xxx/workspace/projects/esp32/my_project/ulp/ulp_main.c.obj: in function `main':
ulp_main.c:(.text.startup.main+0x2e): undefined reference to `bpw34_init'
gabika
Postby gabika » Sun Jul 13, 2025 1:29 pm
On the CMAKE file I see that the CMAKE_FLAGS get ULP_S_SOURCES flag, which might indicate on Assembly sources.
Does anyone knows if C files also supported?
https://github.com/espressif/esp-idf/bl ... .cmake#L61
gabika
Postby gabika » Tue Jul 15, 2025 3:43 pm
This is from GPT, anyone knows if that is true?
ULP code cannot call functions from the main app unless you provide ULP-specific copies and include them in the ULP build step.
MicroController
Postby MicroController » Tue Jul 15, 2025 7:31 pm
Yes, that is accurate.
Source files don't necessarily have to be "ULP-specific" though, namely when they don't need to access the hardware, FreeRTOS, or other functionality only available to the main CPU.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
