Surprised to find this board doesn't fit normal male header pins, because the drilled holes are too small.
Fortunately I had a set of stacking header pins which use very thin pressed plate pins/contacts [crap due to easy bending]
The pin spacing is 2.54mm as expected, but the hole size is too small for standard pins, is this a known issue with the Espressif ESP32-C3 Rust devkit?
ESP32 Rust devkit doesn't support normal size header pins - holes too small
tyethgundry
tyethgundry
