ESP32 kernel hang
Vitalii_Bondarenko
ESP32 kernel hang
Postby Vitalii_Bondarenko » Fri Aug 08, 2025 11:17 am
I am writing a program for ESP 32, in the platformio environment, using the Arduino framework. IDF-5.3.2 .
I use as a basis a debug board - ESP-WROOM-32 ESP32 30 Pin, which is inserted into my cross board with the rest of the harness.
Platform.ini file -
[env:esp32dev]
platform = espressif32
board = esp32dev
framework = arduino
monitor_speed = 115200
upload_port = COM31
monitor_port = COM31
board_build.partitions = partitions.csv
monitor_filters = esp32_exception_decoder
lib_deps =
	arduino-libraries/Arduino_JSON @ 0.1.0
	esp32async/ESPAsyncWebServer@^3.7.0
The program works on ModBus, I have two lines. It works on MQTT, transmitting and receiving data. And it also works as a web server. I use wired Internet via W5500.
I write all the code using only the functions of the IDF framework, except for the web server, this is the only Arduino library that I use.
Once a day I do a forced reboot of the controller, through - esp_restart();
Initially, I did not configure any WDT myself, but the controller froze once every three days, although I reboot it every day(24 h).
I assumed that the system itself turns on the WDT timer and in case of freezing it will reset the MС.
Then I added some code where I also set the WDT for one of the tasks, a simple task that just resets the timer. Here is the WDT setup code.
void FnInitWDT(void)
  esp_err_t err;
  esp_task_wdt_config_t cfg_wdt;
  cfg_wdt.timeout_ms = WDT_TIME_OUT;
  cfg_wdt.trigger_panic = true;
  cfg_wdt.idle_core_mask = 0x00;
  err = esp_task_wdt_init(&cfg_wdt);
  if(err!=ESP_OK) ESP_LOGE(TAG,"ERR_INIT WDT");
  err = esp_task_wdt_add(NULL);
    if(err!=ESP_OK) ESP_LOGE(TAG,"ERR_ADD WDT");
Code in task -
for(;;) //infinite cycle in task
  ulTaskNotifyTake(pdTRUE, 100/portTICK_PERIOD_MS);
      esp_task_wdt_reset();
Well, two weeks after my modification, with the timer, the controller froze again. That is, it worked for two weeks without freezing and froze.
How can it be that the WDT does not reset the MC in case of a freeze?
No other MC works like this, if the system freezes - the hardware timer of the WDT must reset the microcontroller.
I ask for help with this problem.
MicroController
Re: ESP32 kernel hang
Postby MicroController » Fri Aug 08, 2025 11:33 am
How do you come to the conclusion that the "controller" or the "system" freezes?
Every WDT works like this. As long as the WDT is reset regularily, it doesn't do anything.
This suggests that "the system" did not "freeze", at least as far as the idle tasks and your watchdog-resetting task are concerned. So the question remains: What is the symptom you observe that indicates a freeze of "the system"? Which of your tasks stops working properly? Are your tasks registered with the task WDT?
vvb333007
Contact:
Postby vvb333007 » Sun Aug 10, 2025 4:01 am
2 weeks delays before freeze may tell about some counter overflows.
Some counters somewhere.
Did you try to run your code with parts of it disabled? Still freezes?
Thanks!
Slava.
dmitrij999
Postby dmitrij999 » Sun Aug 10, 2025 4:45 am
Could you please check and try to use vTaskDelay([at least one tick]) in loops?
In FreeRTOS, it says to scheduler that "not to switch to this task for this number of ticks". As well, it lets the scheduler to switch to another tasks and handle them correctly
Vitalii_Bondarenko
Postby Vitalii_Bondarenko » Mon Aug 11, 2025 8:19 am
I haven't tried running it with separate parts, so I can't say, unfortunately.
Vitalii_Bondarenko
Postby Vitalii_Bondarenko » Mon Aug 11, 2025 8:23 am
I do a forced reboot of the MС inside the program once a day to avoid such problems. Although I am already working on the program so that such a problem does not exist in principle. Even if some counters were to overflow, it would simply affect the correct operation of the system, but not freeze.
Vitalii_Bondarenko
Postby Vitalii_Bondarenko » Mon Aug 11, 2025 8:43 am
All my tasks have a section of code where they pass control to the scheduler. Calls -xRingbufferReceive, ulTaskNotifyTake, xQueueReceive.
If at least one task did not have a function that transferred it to the state - Blocked. Then I would have received the WDT triggering a few seconds after the program started, I can say that for sure.
The waiting time that I set in the blocking function of FreeRTOS is either 100 ms, or even portMAX_DELAY.
Users browsing this forum: pdragun, PetalBot and 2 guests
