I'm trying to drive high the GPIO 19 and 22 PINs on the ESP-C6-MINI-1U module.
I'm doing it with AT+SYSREG because I have 3250 modules with AT V4.0.0 firmware .
The sequence I'm doing is this:
AT+RESTORE
OK
AT+SYSREG=1,0x600B4928,0x00001200 //MUX SET GPIO19
OK
AT+SYSREG=0,0x600B4928 //Read if the set is done
+SYSREG:0x0 (The register doesn't write)
AT+SYSREG=1,0x600B4934,0x00001200 //MUX SET GPIO22
AT+SYSREG=0,0x600B4934 //Read if the set is done
AT+SYSREG=1,0x60091020,0x00480000 // Configure outputs
OK
AT+SYSREG=1,0x60091004,0x00480000 // Drive High the pins
OK
The main problem is that the mux doesn't write, but I just need to achiueve to set the two pins at logic level HIGH
Someone can please provide me the correct sequence?
Set outputs with AT commands
Re: Set outputs with AT commands
Not sure where you got that address from. The TRM specifies the IO mux addresses start from at 0x60090000.AT+SYSREG=1,0x600B4928,0x00001200 //MUX SET GPIO19
OK
(Also note that GPIO19 by default is routed to the USB-JTAG-serial device. You may need to disable the PHY of that subsystem before the GPIO will react as you'd expect.)
Materia_Labs
Thank you Sprite for the support!
As you told me: PIN 19 and PIN 22 were not configured as GPIO
In fact SDIO Pin Mapping on ESP32-C6
The SDIO interface uses specific GPIO pins:
GPIO18: SDIO_CMD (Command line)
GPIO19: SDIO_CLK (Clock line)
GPIO20: SDIO_DATA0 (Data line 0)
GPIO21: SDIO_DATA1 (Data line 1)
GPIO22: SDIO_DATA2 (Data line 2)
GPIO23: SDIO_DATA3 (Data line 3)
This is the correct sequence that worked for me
AT+SYSREG=1,0x60090050,0x1a02 // Configure PIN 19 as GPIO (not SDIO)
AT+SYSREG=1,0x6009005C,0x1a02 // Configure PIN 22 as GPIO (not SDIO)
AT+SYSREG=1,0x60091020,0x00480000 // Enable GPIO19 & 22 as outputs
AT+SYSREG=1,0x60091004,0x00480000 // Drive HIGH (3.3V) GPIO19 & 22
AT+SYSREG=1,0x60091004,0x0 // Drive LOW GPIO19 & 22
Thank you for the support!
