I am Using ESP32-S3 and External Flash MT25QU256ABA1EW7-0SIT[FLASH - NOR Memory IC 256Mbit SPI - Quad I/O 133 MHz 8-WPDFN (6x5)(MLP8)].
Firmware is developed in Arduino framework. But after flashing i am getting below error
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x7 (TG0WDT_SYS_RST),boot:0x2f (SPI_FAST_FLASH_BOOT)
Saved PC:0x40043ac8
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x41c
load:0x3c970000,len:0x9a8ff
Invalid image block, can't boot.
ets_main.c 329
Build:Mar 27 2021
Saved PC:0x40043ac8
SPIWP:0xee
ets_main.c 329
Build:Mar 27 2021
rst:0x10 (RTCWDT_RTC_RST),boot:0x2f (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
ets_main.c 329
Since firmware is developed in Arduino environment so to make it work under esp-idf framework I am using VS code extension PlatformIO and also did memory partition according to External flash size(32MB), Still facing same issue.
I am attaching Partition file, main.ino, sdkconfig_defaults, platformio.ini for reference
NOTE :
On the same Board I tried to upload basic HelloWorld program from esp-idf framework, it worked successfully without any issue.
But when i am running my firmware which is using Arduino IDE and Libraries, I am getting error after flashing Firmware is not loading.
I also Tried with platformIO extension to take help of esp-idf framework in modifying sdkconfig still facing the same issue
Please look into the issue; your support would be greatly appreciated.
Using ESP32S3 and External Flash MT25QU256ABA1EW7-0SIT.After Flashing Firmware is giving error,
rinibanzal
- sdkconfig.defaults.txt
- sdkconfig.defaults file
- (65.95 KiB) Downloaded 7 times
- platformio.ini
- (796 Bytes) Downloaded 7 times
- partitions_32mb.csv
- (314 Bytes) Downloaded 6 times
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], Qwantbot and 2 guests
