Cannot compile / build simplest program
sckidinlv
Postby sckidinlv » Fri Aug 22, 2025 6:27 pm
Building in: D:\Development\Espressif\Workspace\EnvironmentalLogger\build
Configuring in: D:\Development\Espressif\Workspace\EnvironmentalLogger\build
cmake -G Ninja -DCMAKE_TOOLCHAIN_FILE=D:\Development\Espressif\frameworks\esp-idf-v5.5\tools\cmake\toolchain-esp32s3.cmake -DPYTHON_DEPS_CHECKED=1 -DPYTHON=D:\Development\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe -DESP_PLATFORM=1 -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCCACHE_ENABLE=1 -DIDF_TARGET=esp32s3 D:\Development\Espressif\Workspace\EnvironmentalLogger
-- Minimal build - OFF
-- ccache will be used for faster recompilation
-- git rev-parse returned 'fatal: not a git repository (or any of the parent directories): .git'
-- Could not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32s3
NOTICE: Optional dependency "espressif/esp-zigbee-lib" of "espressif/arduino-esp32 (3.3.0~1)" is not present in the lock file, solving dependencies.
NOTICE: Skipping optional dependency: espressif/esp_hosted
NOTICE: Skipping optional dependency: espressif/esp_wifi_remote
NOTICE: Using component placed at D:\Development\Espressif\frameworks\esp-idf-v5.5\components\esp-zigbee-lib for dependency "espressif/esp-zigbee-lib", specified in D:\Development\Espressif\frameworks\esp-idf-v5.5\components\arduino-esp32\idf_component.yml
..........................................NOTICE: Using component placed at D:\Development\Espressif\frameworks\esp-idf-v5.5\components\esp-zigbee-lib for dependency "espressif/esp-zigbee-lib"(introduced by component "espressif/arduino-esp32"), specified in D:\Development\Espressif\Workspace\EnvironmentalLogger\main\idf_component.yml
...........NOTICE: Skipping optional dependency: espressif/esp_hosted
...NOTICE: Skipping optional dependency: espressif/esp_wifi_remote
NOTICE: Processing 25 dependencies:
NOTICE: [1/25] chmorgan/esp-libhelix-mp3 (1.0.3)
NOTICE: [2/25] espressif/cbor (0.6.0~1)
NOTICE: [3/25] espressif/esp-dsp (1.4.12)
NOTICE: [4/25] espressif/esp-modbus (1.0.18)
NOTICE: [5/25] espressif/esp-serial-flasher (0.0.11)
NOTICE: [6/25] espressif/esp-sr (1.9.5)
NOTICE: [7/25] espressif/esp-zboss-lib (1.6.4)
NOTICE: [8/25] espressif/esp_diag_data_store (1.0.2)
NOTICE: [9/25] espressif/esp_diagnostics (1.2.1)
NOTICE: [10/25] espressif/esp_insights (1.2.2)
NOTICE: [11/25] espressif/esp_modem (1.4.0)
NOTICE: [12/25] espressif/esp_rainmaker (1.5.2)
NOTICE: [13/25] espressif/esp_rcp_update (1.2.0)
NOTICE: [14/25] espressif/esp_schedule (1.2.0)
NOTICE: [15/25] espressif/esp_secure_cert_mgr (2.5.1)
NOTICE: [16/25] espressif/jsmn (1.1.0)
NOTICE: [17/25] espressif/json_generator (1.1.2)
NOTICE: [18/25] espressif/json_parser (1.0.3)
NOTICE: [19/25] espressif/libsodium (1.0.20~2)
NOTICE: [20/25] espressif/mdns (1.8.2)
NOTICE: [21/25] espressif/network_provisioning (1.0.2)
NOTICE: [22/25] espressif/qrcode (0.1.0~2)
NOTICE: [23/25] espressif/rmaker_common (1.4.6)
NOTICE: [24/25] joltwallet/littlefs (1.20.1)
NOTICE: [25/25] idf (5.5.0)
-- DEBUG: Use esp-modbus component folder: D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp-modbus.
-- Project sdkconfig file D:/Development/Espressif/Workspace/EnvironmentalLogger/sdkconfig
-- Compiler supported targets: xtensa-esp-elf
-- USING O3
-- App "app-template" version: 1
-- Adding linker script D:/Development/Espressif/Workspace/EnvironmentalLogger/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script D:/Development/Espressif/Workspace/EnvironmentalLogger/build/esp-idf/esp_system/ld/sections.ld.in
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.api.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.bt_funcs.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.libgcc.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.wdt.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.version.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ble_master.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ble_50.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ble_smp.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ble_dtm.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ble_test.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.ble_scan.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.libc.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom/esp32s3/ld/esp32s3.rom.newlib.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/soc/esp32s3/ld/esp32s3.peripherals.ld
ESP Insights Project commit: HEAD-HASH-NOTFOUND
ESP RainMaker Project commit: HEAD-HASH-NOTFOUND
-- Components: app_trace app_update arduino-esp32 bootloader bootloader_support bt chmorgan__esp-libhelix-mp3 cmock console cxx driver efuse esp-tls esp-zigbee-lib esp_adc esp_app_format esp_bootloader_format esp_coex esp_common esp_driver_ana_cmpr esp_driver_bitscrambler esp_driver_cam esp_driver_dac esp_driver_gpio esp_driver_gptimer esp_driver_i2c esp_driver_i2s esp_driver_isp esp_driver_jpeg esp_driver_ledc esp_driver_mcpwm esp_driver_parlio esp_driver_pcnt esp_driver_ppa esp_driver_rmt esp_driver_sdio esp_driver_sdm esp_driver_sdmmc esp_driver_sdspi esp_driver_spi esp_driver_touch_sens esp_driver_tsens esp_driver_twai esp_driver_uart esp_driver_usb_serial_jtag esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_mm esp_netif esp_netif_stack esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_security esp_system esp_timer esp_vfs_console esp_wifi espcoredump espressif__cbor espressif__esp-dsp espressif__esp-modbus espressif__esp-serial-flasher espressif__esp-sr espressif__esp-zboss-lib espressif__esp_diag_data_store espressif__esp_diagnostics espressif__esp_insights espressif__esp_modem espressif__esp_rainmaker espressif__esp_rcp_update espressif__esp_schedule espressif__esp_secure_cert_mgr espressif__jsmn espressif__json_generator espressif__json_parser espressif__libsodium espressif__mdns espressif__network_provisioning espressif__qrcode espressif__rmaker_common esptool_py fatfs freertos hal heap http_parser idf_test ieee802154 joltwallet__littlefs json log lwip main mbedtls mqtt newlib nvs_flash nvs_sec_provider openthread partition_table perfmon protobuf-c protocomm pthread rt sdmmc soc spi_flash spiffs tcp_transport touch_element ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: D:/Development/Espressif/frameworks/esp-idf-v5.5/components/app_trace D:/Development/Espressif/frameworks/esp-idf-v5.5/components/app_update D:/Development/Espressif/frameworks/esp-idf-v5.5/components/arduino-esp32 D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader_support D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bt D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/chmorgan__esp-libhelix-mp3 D:/Development/Espressif/frameworks/esp-idf-v5.5/components/cmock D:/Development/Espressif/frameworks/esp-idf-v5.5/components/console D:/Development/Espressif/frameworks/esp-idf-v5.5/components/cxx D:/Development/Espressif/frameworks/esp-idf-v5.5/components/driver D:/Development/Espressif/frameworks/esp-idf-v5.5/components/efuse D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp-tls D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp-zigbee-lib D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_adc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_app_format D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_bootloader_format D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_coex D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_common D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_ana_cmpr D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_bitscrambler D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_cam D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_dac D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_gpio D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_gptimer D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_i2c D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_i2s D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_isp D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_jpeg D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_ledc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_mcpwm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_parlio D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_pcnt D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_ppa D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_rmt D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_sdio D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_sdm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_sdmmc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_sdspi D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_spi D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_touch_sens D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_tsens D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_twai D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_uart D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_usb_serial_jtag D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_eth D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_event D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_gdbstub D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_hid D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_http_client D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_http_server D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_https_ota D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_https_server D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_hw_support D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_lcd D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_local_ctrl D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_mm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_netif D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_netif_stack D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_partition D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_phy D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_pm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_psram D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_ringbuf D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_security D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_system D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_timer D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_vfs_console D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_wifi D:/Development/Espressif/frameworks/esp-idf-v5.5/components/espcoredump D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__cbor D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp-dsp D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp-modbus D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp-serial-flasher D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp-sr D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp-zboss-lib D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_diag_data_store D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_diagnostics D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_insights D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_modem D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_rainmaker D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_rcp_update D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_schedule D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__esp_secure_cert_mgr D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__jsmn D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__json_generator D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__json_parser D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__libsodium D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__mdns D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__network_provisioning D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__qrcode D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/espressif__rmaker_common D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esptool_py D:/Development/Espressif/frameworks/esp-idf-v5.5/components/fatfs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/freertos D:/Development/Espressif/frameworks/esp-idf-v5.5/components/hal D:/Development/Espressif/frameworks/esp-idf-v5.5/components/heap D:/Development/Espressif/frameworks/esp-idf-v5.5/components/http_parser D:/Development/Espressif/frameworks/esp-idf-v5.5/components/idf_test D:/Development/Espressif/frameworks/esp-idf-v5.5/components/ieee802154 D:/Development/Espressif/Workspace/EnvironmentalLogger/managed_components/joltwallet__littlefs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/json D:/Development/Espressif/frameworks/esp-idf-v5.5/components/log D:/Development/Espressif/frameworks/esp-idf-v5.5/components/lwip D:/Development/Espressif/Workspace/EnvironmentalLogger/main D:/Development/Espressif/frameworks/esp-idf-v5.5/components/mbedtls D:/Development/Espressif/frameworks/esp-idf-v5.5/components/mqtt D:/Development/Espressif/frameworks/esp-idf-v5.5/components/newlib D:/Development/Espressif/frameworks/esp-idf-v5.5/components/nvs_flash D:/Development/Espressif/frameworks/esp-idf-v5.5/components/nvs_sec_provider D:/Development/Espressif/frameworks/esp-idf-v5.5/components/openthread D:/Development/Espressif/frameworks/esp-idf-v5.5/components/partition_table D:/Development/Espressif/frameworks/esp-idf-v5.5/components/perfmon D:/Development/Espressif/frameworks/esp-idf-v5.5/components/protobuf-c D:/Development/Espressif/frameworks/esp-idf-v5.5/components/protocomm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/pthread D:/Development/Espressif/frameworks/esp-idf-v5.5/components/rt D:/Development/Espressif/frameworks/esp-idf-v5.5/components/sdmmc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/soc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/spi_flash D:/Development/Espressif/frameworks/esp-idf-v5.5/components/spiffs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/tcp_transport D:/Development/Espressif/frameworks/esp-idf-v5.5/components/touch_element D:/Development/Espressif/frameworks/esp-idf-v5.5/components/ulp D:/Development/Espressif/frameworks/esp-idf-v5.5/components/unity D:/Development/Espressif/frameworks/esp-idf-v5.5/components/usb D:/Development/Espressif/frameworks/esp-idf-v5.5/components/vfs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/wear_levelling D:/Development/Espressif/frameworks/esp-idf-v5.5/components/wifi_provisioning D:/Development/Espressif/frameworks/esp-idf-v5.5/components/wpa_supplicant D:/Development/Espressif/frameworks/esp-idf-v5.5/components/xtensa
-- Configuring done (13.0s)
-- Generating done (0.8s)
-- Build files have been written to: D:/Development/Espressif/Workspace/EnvironmentalLogger/build
cmake --build . -- -v
[1/5] C:\WINDOWS\system32\cmd.exe /C "cd /D D:\Development\Espressif\Workspace\EnvironmentalLogger\build\esp-idf\esptool_py && D:\Development\Espressif\python_env\idf5.5_py3.11_env\Scripts\python.exe D:/Development/Espressif/frameworks/esp-idf-v5.5/components/partition_table/check_sizes.py --offset 0x8000 partition --type app D:/Development/Espressif/Workspace/EnvironmentalLogger/build/partition_table/partition-table.bin D:/Development/Espressif/Workspace/EnvironmentalLogger/build/app-template.bin"
app-template.bin binary size 0x3cf60 bytes. Smallest app partition is 0x100000 bytes. 0xc30a0 bytes (76%) free.
[2/5] C:\WINDOWS\system32\cmd.exe /C "cd /D D:\Development\Espressif\Workspace\EnvironmentalLogger\build\bootloader && D:\Development\Espressif\tools\cmake\3.30.2\bin\cmake.exe -DSDKCONFIG=D:/Development/Espressif/Workspace/EnvironmentalLogger/sdkconfig -DIDF_PATH=D:/Development/Espressif/frameworks/esp-idf-v5.5 -DIDF_TARGET=esp32s3 -DPYTHON_DEPS_CHECKED=1 -DPYTHON=D:/Development/Espressif/python_env/idf5.5_py3.11_env/Scripts/python.exe -DEXTRA_COMPONENT_DIRS=D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader -DPROJECT_SOURCE_DIR=D:/Development/Espressif/Workspace/EnvironmentalLogger -DIGNORE_EXTRA_COMPONENT= -GNinja -S D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject -B D:/Development/Espressif/Workspace/EnvironmentalLogger/build/bootloader && D:\Development\Espressif\tools\cmake\3.30.2\bin\cmake.exe -E touch D:/Development/Espressif/Workspace/EnvironmentalLogger/build/bootloader-prefix/src/bootloader-stamp/bootloader-configure"
FAILED: bootloader-prefix/src/bootloader-stamp/bootloader-configure D:/Development/Espressif/Workspace/EnvironmentalLogger/build/bootloader-prefix/src/bootloader-stamp/bootloader-configure
-- DEBUG: Use esp-modbus component folder: D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp-modbus.
-- Bootloader project name: "bootloader" version: 1
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/main/ld/esp32s3/bootloader.ld
-- Adding linker script D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/main/ld/esp32s3/bootloader.rom.ld
CMake Error at managed_components/espressif__esp-sr/CMakeLists.txt:113 (add_dependencies):
Cannot add target-level dependencies to non-existent target "flash".
The add_dependencies works for top-level logical targets created by the
add_executable, add_library, or add_custom_target commands. If you want to
add file-level dependencies see the DEPENDS option of the add_custom_target
and add_custom_command commands.
usage: ESP-IDF Partitions Tool [-h] [--quiet]
[--esptool-args ESPTOOL_ARGS [ESPTOOL_ARGS ...]]
[--esptool-write-args ESPTOOL_WRITE_ARGS [ESPTOOL_WRITE_ARGS ...]]
[--esptool-read-args ESPTOOL_READ_ARGS [ESPTOOL_READ_ARGS ...]]
[--esptool-erase-args ESPTOOL_ERASE_ARGS [ESPTOOL_ERASE_ARGS ...]]
[--port PORT] [--baud BAUD]
[--partition-table-offset PARTITION_TABLE_OFFSET]
[--primary-bootloader-offset PRIMARY_BOOTLOADER_OFFSET]
[--recovery-bootloader-offset RECOVERY_BOOTLOADER_OFFSET]
[--partition-table-file PARTITION_TABLE_FILE]
{read_partition,write_partition,erase_partition,get_partition_info}
ESP-IDF Partitions Tool: error: argument operation: invalid choice: 'model' (choose from 'read_partition', 'write_partition', 'erase_partition', 'get_partition_info')
CMake Warning at D:/Development/Espressif/frameworks/esp-idf-v5.5/components/partition_table/project_include.cmake:84 (message):
parttool.py execution failed (size), problem with partition CSV file (see
above)
managed_components/espressif__esp-sr/CMakeLists.txt:115 (partition_table_get_partition_info)
parttool.py execution failed (offset), problem with partition CSV file (see
above)
managed_components/espressif__esp-sr/CMakeLists.txt:116 (partition_table_get_partition_info)
ESP Insights Project commit: v5.5-dirty
ESP RainMaker Project commit: v5.5-dirty
-- Components: app_update bootloader bootloader_support bt chmorgan__esp-libhelix-mp3 console driver efuse esp-tls esp_app_format esp_bootloader_format esp_coex esp_common esp_driver_gpio esp_driver_spi esp_driver_uart esp_driver_usb_serial_jtag esp_event esp_gdbstub esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_local_ctrl esp_mm esp_netif esp_netif_stack esp_partition esp_phy esp_pm esp_ringbuf esp_rom esp_security esp_system esp_timer esp_vfs_console esp_wifi espcoredump espressif__cbor espressif__esp-dsp espressif__esp-modbus espressif__esp-serial-flasher espressif__esp-sr espressif__esp-zboss-lib espressif__esp_diag_data_store espressif__esp_diagnostics espressif__esp_insights espressif__esp_modem espressif__esp_rainmaker espressif__esp_rcp_update espressif__esp_schedule espressif__esp_secure_cert_mgr espressif__jsmn espressif__json_generator espressif__json_parser espressif__libsodium espressif__mdns espressif__network_provisioning espressif__qrcode espressif__rmaker_common esptool_py freertos hal heap http_parser ieee802154 joltwallet__littlefs json log lwip main mbedtls micro-ecc mqtt newlib nvs_flash openthread partition_table protobuf-c protocomm sdmmc soc spi_flash spiffs tcp_transport vfs wifi_provisioning wpa_supplicant xtensa
-- Component paths: D:/Development/Espressif/frameworks/esp-idf-v5.5/components/app_update D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader_support D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bt D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/chmorgan__esp-libhelix-mp3 D:/Development/Espressif/frameworks/esp-idf-v5.5/components/console D:/Development/Espressif/frameworks/esp-idf-v5.5/components/driver D:/Development/Espressif/frameworks/esp-idf-v5.5/components/efuse D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp-tls D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_app_format D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_bootloader_format D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_coex D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_common D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_gpio D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_spi D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_uart D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_driver_usb_serial_jtag D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_event D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_gdbstub D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_http_client D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_http_server D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_https_ota D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_https_server D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_hw_support D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_local_ctrl D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_mm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_netif D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_netif_stack D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_partition D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_phy D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_pm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_ringbuf D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_rom D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_security D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_system D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_timer D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_vfs_console D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esp_wifi D:/Development/Espressif/frameworks/esp-idf-v5.5/components/espcoredump D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__cbor D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp-dsp D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp-modbus D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp-serial-flasher D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp-sr D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp-zboss-lib D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_diag_data_store D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_diagnostics D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_insights D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_modem D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_rainmaker D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_rcp_update D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_schedule D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__esp_secure_cert_mgr D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__jsmn D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__json_generator D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__json_parser D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__libsodium D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__mdns D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__network_provisioning D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__qrcode D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/espressif__rmaker_common D:/Development/Espressif/frameworks/esp-idf-v5.5/components/esptool_py D:/Development/Espressif/frameworks/esp-idf-v5.5/components/freertos D:/Development/Espressif/frameworks/esp-idf-v5.5/components/hal D:/Development/Espressif/frameworks/esp-idf-v5.5/components/heap D:/Development/Espressif/frameworks/esp-idf-v5.5/components/http_parser D:/Development/Espressif/frameworks/esp-idf-v5.5/components/ieee802154 D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/managed_components/joltwallet__littlefs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/json D:/Development/Espressif/frameworks/esp-idf-v5.5/components/log D:/Development/Espressif/frameworks/esp-idf-v5.5/components/lwip D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/main D:/Development/Espressif/frameworks/esp-idf-v5.5/components/mbedtls D:/Development/Espressif/frameworks/esp-idf-v5.5/components/bootloader/subproject/components/micro-ecc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/mqtt D:/Development/Espressif/frameworks/esp-idf-v5.5/components/newlib D:/Development/Espressif/frameworks/esp-idf-v5.5/components/nvs_flash D:/Development/Espressif/frameworks/esp-idf-v5.5/components/openthread D:/Development/Espressif/frameworks/esp-idf-v5.5/components/partition_table D:/Development/Espressif/frameworks/esp-idf-v5.5/components/protobuf-c D:/Development/Espressif/frameworks/esp-idf-v5.5/components/protocomm D:/Development/Espressif/frameworks/esp-idf-v5.5/components/sdmmc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/soc D:/Development/Espressif/frameworks/esp-idf-v5.5/components/spi_flash D:/Development/Espressif/frameworks/esp-idf-v5.5/components/spiffs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/tcp_transport D:/Development/Espressif/frameworks/esp-idf-v5.5/components/vfs D:/Development/Espressif/frameworks/esp-idf-v5.5/components/wifi_provisioning D:/Development/Espressif/frameworks/esp-idf-v5.5/components/wpa_supplicant D:/Development/Espressif/frameworks/esp-idf-v5.5/components/xtensa
Build complete (2 errors, 0 warnings): D:\Development\Espressif\Workspace\EnvironmentalLogger\build
Total time taken to build the project: 20,123 ms
sckidinlv
Re: Cannot compile / build simplest program
Postby sckidinlv » Mon Aug 25, 2025 6:31 pm
I have exactly the same problem.
I dont even want to use ESP_SR but totally kills my build process
CMake Warning at D:/Development/Espressif/frameworks/v5.5/esp-idf/components/partition_table/project_include.cmake:84 (message):
above)
above)
Users browsing this forum: Baidu [Spider], ChatGPT-User and 3 guests
