ESP32S2 ADC different attenuation on every channel
pc1010
Postby pc1010 » Wed Apr 12, 2023 10:12 am
Hello everyone!
I'm having an issue with setting different attenuation on ADC channels with IDF 5.0.1 using adc_continuous_config function.
Whenever I do it, the function is aborting with "ESP_ERROR_CHECK failed: esp_err_t 0x102 (ESP_ERR_INVALID_ARG)".
I see that in adc_continuous.c:588 there is a check "} else if (handle->adc1_atten != pat->atten) {" that checks if all channels have the same attenuation.
In previous releases it was possible to configure it separately :?
ginspe
Re: ESP32S2 ADC different attenuation on every channel
Postby ginspe » Wed Sep 17, 2025 8:17 am
Please fix this issue.
Minatel
Postby Minatel » Wed Sep 17, 2025 11:44 am
Are you facing the same issue with the ESP32-S2, @ginspe?
I see another topic created by you here.
ginspe
Postby ginspe » Wed Sep 17, 2025 11:57 am
No it's with C6. Saw this topic was quite old so I thought I'd start a new one. But the issue still stands.
Users browsing this forum: Amazon [Bot] and 2 guests
