Im on Xubuntu operating system.
I have cloned this repo https://github.com/espressif/esp-idf after it was cloned
I have ran the install script ./install.sh and it always stops when trying to download this link here https://github.com/espressif/crosstool- ... gnu.tar.xz
It always stops when it is at 66%, I have tried to download it manually and also it stops after 66%,
What could be the issue can someone assist? Thanks for your time!
Installtion Issue
wizard612powerz
Re: Installtion Issue
If you are experiencing issues downloading the toolchain file from GitHub (such as the download reaching 98% and then restarting repeatedly), the Espressif documentation suggests an alternative approach: you can set an environment variable to prefer Espressif's own download server for GitHub asset downloads. This can help if GitHub is slow or unreliable in your region.
To do this, run the following commands before running the install script:
If you are in China, you can use the China-based server for faster downloads:
This setting only affects the download of individual tools from GitHub releases and does not change the URLs used to access any Git repositories. If you wish to customize the tools installation path, make sure to export the IDF_TOOLS_PATH variable before running the script as well.
cd ~/esp/esp-idf
export IDF_GITHUB_ASSETS="dl.espressif.com/github_assets"
./install.shCode: Select all
cd ~/esp/esp-idf
export IDF_GITHUB_ASSETS="dl.espressif.cn/github_assets"
./install.shWho is online
