Using module with 8/16MB Flash for ESP-AT
DexterM
Postby DexterM » Mon Oct 27, 2025 2:50 pm
I need to add to standard firmware:
- Ethernet commands
- WebSocket commands
- FS commands with 512kB partition for user space
- BLE commands
Also need OTA service.
ESP32-WROOM32UEN4 have to small Flash memory. Can I use bigger one (8M/16M)?
Have to adjust partition table only or other things also? Or can't use it?
esp-at
Re: Using module with 8/16MB Flash for ESP-AT
Postby esp-at » Thu Nov 13, 2025 10:07 am
@DexterM Of course. If FS partition only requires 512 KB, you can use an ESP32-WROOM module with 8 MB of flash. You'll need to adjust the partition table files partitions_at.csv and at_customize.csv, as well as some partition-related configurations in sdkconfig.defaults. If you run into any difficulties, I can help you resolve them.
Users browsing this forum: YisouSpider and 1 guest
