I purchased the ESP32-LyraTD-SYNA development board.
The documentation of the board sends me to an SDK with supposedly example code to work with Amazon Alexa.
https://www.espressif.com/sites/default ... de__EN.pdf
https://github.com/espressif/esp-va-sdk
The board ESP32-LyraTD-SYNA is not defined in the audio board and the audio codec of this board is CX20721, but in the components\audio_hal\driver directory of the SDK, there are only drivers for es83 series and other chips.
Does this evaluation board have some example code working of do we have to remake everything?
Best regards
Augustin,
ESP32-LyraTD-SYNA working example code not found
manoj.balakrishnan
Warpage specification and SOP for ESP32-S3-WROOM-1-N8R2
Hi Experts ,
Good Day ,
Can you please check and send the standard SOP procedure for Warpage specifications for ESPRESSIF products ?
No warpage spec in its product spec as pdf attached, please help share its warpage spec and how to measure its warpage .
Looking forward for your valuable support.
Thank you
Regards
Manoj Balakrishnan.
Good Day ,
Thank you
Regards
Manoj Balakrishnan.
Re: Warpage specification and SOP for ESP32-S3-WROOM-1-N8R2
You are posting on a wrong subforum, as a reply under an unrelated post, on a question that the community here is unlikely to be able to help you with. Suggest you send an email to sales@espressif.com insteadHi Experts ,
asifkhan95
Re: ESP32-LyraTD-SYNA working example code not found
Why no response about this board why there is no support fro this board?
Users browsing this forum: Semrush [Bot] and 1 guest
