Hi.
I'm trying to seta debugging environment outside Ubuntu, that works really fine.
I tried using Windows, WsL and even docker and i have problems..
1. In Docker, when i try to create a gdbgui environment with monitor output (that's to say, i use idf.py gdbgui monitor), devices go crazy and my JTAG disconects
2. In WSL devices go extremely slow and openocd gives me frequent timeouts. I did ot try with monitor output.
3. In Windows by ESP-CMD openocd directly don't work cause it says drivers are wrong (although i followed their tutorial)
Is there a way to fix one of these 3 ways in order to use gdbgui with monitor in windows?
Debugging esp32c3 in windows
Re: Debugging esp32c3 in windows
Did you try eclipse?
I use eclipse as development and debugging environment on windows and works fine.
I use it for S3 target but i don’t see any reason why it would not work for C3.
Here is the link to documentation
https://docs.espressif.com/projects/esp ... er-eclipse
- EUtrilla2002
Thanks for the answer!!
In fact, i saw this video https://www.youtube.com/watch?v=XGTtMYa7IiMand i was able to debug finally.
Users browsing this forum: Bytespider, PerplexityBot, Semrush [Bot] and 1 guest
