Need Help Finding A Water Flow Sensor
Phillip
Postby Phillip » Mon Nov 03, 2025 9:15 pm
I have two styles of Hall-effect sensors - paddle-wheel (GREDIA GR-S403) and GREDIA YF-B5 with circular flow rotor) but the flow/no-flow data is confusing and not helpful. A pressure sensor would not work either because our water pressure is not constant.
I just would like to know when water is flowing so that I can determine if a hose has broken (or a rodent has chewed through the hose). This will be used in my garden watering project. Perhaps no one makes such an ON/OFF water flow sensor?
Any suggestions would be greatly appreciated.
Thank you.
Phillip
Re: Need Help Finding A Water Flow Sensor
Postby Phillip » Mon Nov 03, 2025 9:27 pm
For the sake of clarity - I just want to know when water is flowing. I am not interested in volume.
Thanks.
Phillip
Postby Phillip » Tue Nov 04, 2025 3:58 am
Update! I have recoded my original water flow sensor code and now its output makes more sense. I now see flow rates of either '0' or a numerical value (float) greater than zero (0) which is what my original code failed to output. I failed to understand just how these water flow sensors needed to be coded.
Thanks!
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], YisouSpider and 1 guest
