I would like to know if it's possible to receive the serial data from the logging serial port (UART0)?
I would like to use the logging until I need to communicate with the ESP32 then I'll use:
esp_log_level_set("*", ESP_LOG_ERROR);
to disable the logging until I have completed my serial setup. I can then re-enable the logging.
Would if be advisable to use a printf() to send data to the serial port or should I use another option?
Regards,
Charles
Logging serial port receive data
Re: Logging serial port receive data
To switch off all error logging, you might try "esp_log_level_set("*", ESP_LOG_NONE);"
You can also intercept logging by supplying your own function to be called to log. This is performed via the function esp_log_set_vprintf() ... however I don't know how to set it back. I'll raise a feature request to have the old function returned when we set a new one.
Users browsing this forum: Qwantbot, Semrush [Bot] and 1 guest
