multi-thread I2C synchronization
MikeLemon
Re: multi-thread I2C synchronization
Postby MikeLemon » Sun Feb 14, 2021 4:26 pm
2+ Years later...
Is there a proper solution yet?
PeterR
Postby PeterR » Tue Feb 16, 2021 11:18 pm
Like Wifi says, mutex. May add an extra mutex but cost is low and you can sleep safe.
Its not normal to use a device/driver from multiple threads. If the driver has to cover these RT bases then the driver would get fat and slow.
So best that these particular use/cases are handled at the application level.
JakubKral
Postby JakubKral » Sat Nov 08, 2025 4:01 pm
You could also use i2c manager to handle it for you. See https://github.com/ropg/i2c_manager
Best regards
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User, PerplexityBot and 3 guests
