Import TLS certificates as files
Matti104
Postby Matti104 » Fri Nov 07, 2025 3:27 pm
Hi, I'm trying to connect my ESP32 S3 DevKitC 1 N16R8 to an MQTT broker using TLS certificates. I'm trying to include them as files to create an automatic update system, but I'm having trouble.
I've tried many methods, but none have worked. Can anyone tell me how to include them correctly?
Thanks in advance.
ves011
Contact:
Re: Import TLS certificates as files
Postby ves011 » Fri Nov 14, 2025 4:39 pm
If you still haven’t found the answer here is how I’m doing on my side when connecting esp32 devices to mosquito MQTT broker using TLS and 2-way certificate authentication.
  1. Edit CMakeLists.txt in the root folder of your project and add the following lines
    target_add_binary_data(${CMAKE_PROJECT_NAME}.elf "path/client.crt" TEXT)
    target_add_binary_data(${CMAKE_PROJECT_NAME}.elf "path/client.key" TEXT)
    target_add_binary_data(${CMAKE_PROJECT_NAME}.elf "path/ca.crt" TEXT)
    Where
    - path/ is the path to your certificates and key
    - client.crt/key is the client certificate and key esp32 mqtt client will use to authenticate to the broker
    - ca.crt is the root ca of your PKI infrastructure , esp32 mqtt client will use to validate broker certificate
  2. modify client configuration file (esp_mqtt_client_config_t) and add the fields below
    esp_mqtt_client_config_t mqtt_cfg = {
    		.broker.verification.certificate = (const char *)ca_cert_pem_start,
    		.credentials = {
    		      .client_id = USER_MQTT,
    		      .authentication = {
    		        .certificate = (const char *)client_cert_pem_start,
    		        .key = (const char *)client_key_pem_start,
  3. make sure …..pem_start fields are declared in external directives like this
    extern const uint8_t client_cert_pem_start[] asm("_binary_client_crt_start");
    extern const uint8_t client_cert_pem_end[] asm("_binary_client_crt_end");
    extern const uint8_t client_key_pem_start[] asm("_binary_client_key_start");
    extern const uint8_t client_key_pem_end[] asm("_binary_client_key_end");
    extern const uint8_t ca_cert_pem_start[] asm("_binary_ca_crt_start");
    extern const uint8_t ca_cert_pem_end[] asm("_binary_ca_crt_end");
... and it should work. at least it does for me :)
nopnop2002
Contact:
Postby nopnop2002 » Tue Nov 18, 2025 7:36 am
If you have information about the MQTT broker you want to use, you may be able to get a more accurate answer.
Craige Hales
Postby Craige Hales » Thu Dec 04, 2025 8:20 pm
several years and versions ago I discovered a trailing nul was needed.
                    EMBED_FILES
#                        "spiffsdata/favicon.ico"
                        "upload_script.html"
# adds a trailing nul? makes it work?
                    EMBED_TXTFILES
                        "certs/cacert.pem"
                        "certs/prvtkey.pem"
note the difference between embed files vs embed txtfiles...a text file got an extra nul byte that prevented something from reading off the end.
Craige
Users browsing this forum: Amazon [Bot] and 1 guest
