Help needed with ESP32-S3 A7670E-4G MQTT: no response over UART
Ayno74
Postby Ayno74 » Wed Dec 10, 2025 10:53 pm
Message:
Hello everyone,
I’m trying to get my ESP32-S3 working with a Waveshare A7670E-4G module, but I can’t get it to respond correctly over UART using Arduino. I’m quite new to Arduino, so please bear with me. I’ve done several tests and I’m a bit stuck. I’m hoping for advice or tips from anyone who has experience with this module.
Hardware:
ESP32-S3
A7670E-4G module (U8 version)
Pins connected for UART1:
MAIN_TXD → GPIO43
MAIN_RXD → GPIO44
Power: 5V 3A stable supply
Module control pins:
POWER_ON
RESET
PWRKEY
Current setup:
USB DIP switch: OFF
4G DIP switch: ON
I’ve tried with USB ON as well.
Software / tools:
Arduino IDE with HardwareSerial (UART1)
Tested AT commands using Tera Term → module responds correctly over USB.
What I’ve tried:
Power on the module with PWRKEY sequence and delays (15s boot wait).
Send basic AT command "AT" → sometimes nothing, even after boot.
Check SIM: AT+CPIN? → shows READY in Tera Term, but not over ESP32 UART.
Check signal: AT+CSQ → works in Tera Term.
Network registration: AT+CREG?, AT+CGREG?, AT+CEREG? → OK in Tera Term.
PDP context: AT+CGDCONT=1,"IP","free" → works in Tera Term.
MQTT sequence using AT commands (CMQTTSTART, CMQTTACCQ, CMQTTCONNECT…) → nothing happens over ESP32 UART.
Differences between my working Tera Term setup and Arduino code:
Pins: UART1 GPIO43/44 vs USB TTL
USB ON vs OFF → module only powered via external 5V + PWRKEY
Delays after commands (Arduino may be too short)
Problem:
With USB OFF and 4G ON, the module does not respond to AT commands from ESP32-S3 at all, although it works fine in Tera Term over USB. I suspect it’s something related to power-on sequence, PWRKEY, or UART timing.
Request:
I’m quite new to Arduino, so I would really appreciate step-by-step guidance. Does anyone have a working Arduino example for ESP32-S3 + A7670E-4G with USB OFF and 4G ON? Or tips on correct pins, power sequence, and timing to get AT commands working over UART?
Thanks in advance for any advice!
#include <Arduino.h>
#include <HardwareSerial.h>
HardwareSerial simSerial(1);  // UART1
#define SIM_RX 43
#define SIM_TX 44
String APN = "free";
String BROKER = "IP";
int PORT = 1883;
String TOPIC = "test/esp32";
// -------------------- Fonctions AT --------------------
String sendAT(String cmd, unsigned long timeout = 2000) {
  simSerial.println(cmd);
  unsigned long start = millis();
  String response = "";
  while (millis() - start < timeout) {
    while (simSerial.available()) {
      char c = simSerial.read();
      response += c;
  Serial.println("AT Response: " + response);
  return response;
// Boucle pour attendre "OK"
bool waitForATReady(int retries = 10) {
  for (int i = 0; i < retries; i++) {
    String resp = sendAT("AT");
    if (resp.indexOf("OK") != -1) return true;
    delay(1000);
  return false;
// -------------------- Vérifications --------------------
bool checkSIM() {
  String resp = sendAT("AT+CPIN?");
  if (resp.indexOf("READY") != -1) {
    Serial.println("SIM OK");
    return true;
  Serial.println("SIM not ready");
  return false;
bool checkSignal() {
  String resp = sendAT("AT+CSQ");
  int rssiIndex = resp.indexOf("+CSQ:");
  if (rssiIndex != -1) {
    int rssi = resp.substring(rssiIndex + 6).toInt();
    Serial.println("RSSI = " + String(rssi));
    if (rssi == 99) return false;
    return true;
  return false;
bool checkNetwork() {
  String cs = sendAT("AT+CREG?");
  String ps1 = sendAT("AT+CGREG?");
  String ps2 = sendAT("AT+CEREG?");
  if (cs.indexOf(",1") != -1 || ps1.indexOf(",1") != -1 || ps2.indexOf(",1") != -1) {
    Serial.println("Network registered");
    return true;
  return false;
bool checkService() {
  String resp = sendAT("AT+CPSI?");
  if (resp.indexOf("NO SERVICE") != -1) {
    Serial.println("No network service");
    return false;
  return true;
// -------------------- PDP Context --------------------
bool setupPDP() {
  sendAT("AT+CGDCONT=1,\"IP\",\"" + APN + "\"");
  sendAT("AT+CGACT=1,1");
  String resp = sendAT("AT+CGACT?");
  if (resp.indexOf("1,1") != -1) {
    Serial.println("PDP active, IP assigned");
    return true;
  return false;
// -------------------- MQTT --------------------
bool mqttPublish(String topic, String payload) {
  sendAT("AT+CMQTTSTART"); // activer MQTT
  delay(2000);
  sendAT("AT+CMQTTACCQ=0,\"ESP32-S3\",0"); // config client
  delay(2000);
  sendAT("AT+CMQTTCONNECT=0,\"tcp://" + BROKER + ":" + String(PORT) + "\",60,1"); // connect broker
  delay(10000);
  // Préparer topic
  simSerial.printf("AT+CMQTTTOPIC=0,%d\r\n", topic.length());
  delay(500);
  simSerial.println(topic);
  delay(500);
  // Préparer payload
  simSerial.printf("AT+CMQTTPAYLOAD=0,%d\r\n", payload.length());
  delay(500);
  simSerial.println(payload);
  delay(500);
  // Publier message
  sendAT("AT+CMQTTPUB=0,1,60");
  delay(3000);
  Serial.println("Published: " + payload);
  return true;
// -------------------- Setup --------------------
void setup() {
  Serial.begin(115200);
  simSerial.begin(115200, SERIAL_8N1, SIM_RX, SIM_TX);
  Serial.println("\n=== ESP32-S3 + A7670E MQTT ===");
  if (!waitForATReady()) {
    Serial.println("Module not responding to AT commands. Halting.");
    while(1);
  while (!checkSIM()) delay(2000);
  while (!checkSignal()) delay(2000);
  while (!checkNetwork()) delay(2000);
  while (!checkService()) delay(2000);
  while (!setupPDP()) delay(2000);
  Serial.println("\nModule ready, publishing first message in 5s...");
  delay(5000);
  mqttPublish(TOPIC, "Hello!");
// -------------------- Loop --------------------
void loop() {
  static uint32_t last = 0;
  if (millis() - last < 10000) return;
  last = millis();
  int r = random(1,101);
  String payload = String(r);
  mqttPublish(TOPIC, payload);
lbernstone
Re: Help needed with ESP32-S3 A7670E-4G MQTT: no response over UART
Postby lbernstone » Thu Dec 11, 2025 6:14 am
I don't have any experience with this module, but I will give you the general advice that the RX pin on the modem needs to connect to the TX pin on the esp32. Try switching the pin numbers and see if that is the magic you need.
Ayno74
Postby Ayno74 » Thu Dec 11, 2025 9:32 am
Hi, thanks for your reply!
I forgot to mention that it's the Waveshare ESP32 S3 A7670-E board. All in one.
lbernstone
Postby lbernstone » Fri Dec 12, 2025 7:30 pm
Make sure in teraterm that the device is outputting at 115200. That is pretty high for GPS NMEA.
You are re-using the pins for Serial (aka Serial0) and your Serial1. While this will likely work, since you initiate Serial1 after, it is bad form. It definitely means that you won't see any logging on Serial, and your prints will interfere with the AT commands.
sovereem
Postby sovereem » Fri Jan 09, 2026 11:37 am
Hello, I have same problem here just wonder if you have found a solution?
thanks Sander
Users browsing this forum: ChatGPT-User, Google [Bot] and 3 guests
