Characters occasionally LOST from log output
jcolebaker
Postby jcolebaker » Mon Dec 15, 2025 3:25 am
We write log messages to the UART debug output using ESP_LOGI, etc.
In a recent build, I have noticed that 1 or 2 characters are occasionally lost from my debug log messages. It is somewhat random but generally happens when the CPU is quite busy. Missing characters are usually near the end of a log message.
The system is otherwise working fine (no crashes) but I am worried that this loss of data from the debug log might be a symptom of some serious problem.
Useful Info:
* Chip: ESP32
* ESP-IDF version 5.5.1
* I am monitoring the logs with a Windows 11 PC. ESP32 is connected via a USB programmer board and USB cable.
* Logging UART baud rate is 115,200.
* Dropped characters have been observed with the ESP-IDF monitor program (`idf.py monitor`) and also other serial terminals such as Teraterm.
Here is an example of a couple of common log message being corrupted (other messages filtered out):
I (...) UI: Auto-off timer restarted.  <==== Correct.
I (...) UI: Auto-off timer restartd.   <==== Missing "e"!
I (...) TRANSMIT: Trigger press, Single read mode <==== Correct.
I (...) TRANSMIT: Trigger press, Single read ode  <==== Borked!
I (...) TRANSMIT: Trigger press, Singleread mode  <==== Borked!
I (...) TRANSMIT: Trigger press, Sinle read mode  <==== Borked!
Here is what I have tried:
* Testing the serial port and cable: I made the "main" task of the app log "The quick brown fox jumped over the lazy dog" at 10 message per second for a long time while the device wasn't doing much else. No lost characters seen. Thus, the USB serial cable seems OK (no random loss of data). When I made the ESP32 do more CPU intensive work, I started to see dropped characters again/ But characters were not dropped from the main task logging, only from tasks which were doing more work.
* Task profiling: - I checked the stack usage of all tasks in case there is a stack overflow. It looks like all tasks have plenty of spare stack space.
* Heap corruption detection: I turned on "HEAP_POISONING_COMPREHENSIVE" config option, and also used the "heap_caps_check_integrity_all" function in various places in my code. No heap corruption was detected.
Could this problem result from the UART buffer overflowing? If that happened, how could I detect it? Would it cause an exception or error?
Is there anything else I should look for?
lichurbagan
Re: Characters occasionally LOST from log output
Postby lichurbagan » Mon Dec 15, 2025 6:01 pm
The issue is expected under high CPU load. ESP_LOG output is best-effort, not guaranteed delivery. UART bandwidth at 115200 baud is easily saturated. Characters drop when TX buffers fill. Dropped characters do not indicate memory corruption. No exception or error is generated by design. Loss near line ends is a classic symptom. Busy tasks generate logs faster than UART drains. Increase baud rate to reduce drops. Reduce logging in time-critical code paths.
Users browsing this forum: Applebot, ChatGPT-User, coccocbot, Qwantbot and 5 guests
