Harware help for esp32
urinetid
Postby urinetid » Mon Dec 08, 2025 1:26 pm
Hello!
I'm working on a hobby project and i need to create a controller for it. It's a ventilation system with 2x big 230v EC fans which can be controlled with 0-10 V control.
I need:
4x temperature sensors
1x co2 sensor
2x humidity sensors.
+ 2x 0-10 V controller for the 2x ec Fans.
-I would like to be able to control the fans based on the sensors value.
-I would want to be able to control the esp32 through wifi.
I never did any esp32 projects before, but i'm good in programming.
I need help with the hardware please. Can someone guide me which board/kit/sensors i need to buy to be able to do these above?
I dont mind if its not the cheapest if its easier to work with.
Any help is highly appreciated. Thank you.
lichurbagan
Re: Harware help for esp32
Postby lichurbagan » Thu Dec 11, 2025 11:37 am
Use an ESP32 DevKit for control and Wi-Fi.
https://www.espressif.com/en/products/devkits
Add an SCD30 for CO₂. Use two SHT31 boards for humidity.
https://sensirion.com/media/documents/2 ... 3x_DIS.pdf
Use four DS18B20 sensors for temperature.
https://www.theengineeringprojects.com/ ... 18b20.html
Control the fans with a DFRobot 0–10 V DAC board. This setup is simple and works well.
nopnop2002
Contact:
Postby nopnop2002 » Fri Dec 19, 2025 8:26 am
I need:
1x co2 sensor
All the components are here.
https://github.com/esp-idf-lib/core
