Datasheet incorrect info? EN pin on ESP32 C3 Wroom 02
EngEmil
Postby EngEmil » Wed Dec 17, 2025 11:32 pm
Hi! I've seem to discovered something interesting regarding the ESP32 C3 WROOM 02 module datasheet.
I made a custom board with this module, and I based my design on the Figure 9-1 (Peripheral Schematics) from the datasheet.
In this figure, there it is a button for enable (EN) pin and a pull-up resistor. Assuming that this pin should always be pulled high, and to enable the module the button pulls the EN pin low. Which activates the module.
However, Table 3-1 (Pin Definitions) seem to describe the function of EN pin differently. The following is stated:
High: on, enables the chip.
Low: off, the chip powers off.
Note: Do not leave the EN pin floating.
Nonetheless, I did design my board based on Figure 9-1, and it seems like the module gets activated after pressing the "enable"-button.
Would it be possible to clarify if the information about EN pin in Table 3-1 is incorrect, or I have misunderstood it?
Best regards,
EngEmil
Minatel
Re: Datasheet incorrect info? EN pin on ESP32 C3 Wroom 02
Postby Minatel » Fri Dec 19, 2025 3:21 pm
On the ESP32-C3-WROOM-02, the EN pin is the chip enable (reset) input:
Function:
High: Chip is enabled and can run normally.
Low: Chip powers off (internal circuits are held in reset / powered down).
Design requirement:
The EN pin must not be left floating; it should be pulled up to 3.3 V (typically via a resistor) and driven low only when you want to reset or power down the chip.
So, when the EN pin is HIGH, the ESP32-C3 will run, and when the EN pin is LOW, it will power the chip off.
MicroController
Postby MicroController » Sat Dec 20, 2025 8:44 pm
More precisely, pressing the button and pulling the pin low does not "activate" the module; releasing the button after it has been pressed is what lets the chip run from its reset state.
Users browsing this forum: Baidu [Spider], Qwantbot and 6 guests
