idf.py build errors/messages
weswitt
Postby weswitt » Tue Dec 16, 2025 5:13 pm
When doing a command line build I'm seeing some errors/messages that I'd like to understand.
1) I see a "CMake Deprecation Warning" about the cmake_minimum_required. Is this caused by the fact that I'm using a current version of cmake?
2) I get the error "IDF_TARGET is not set, guessed esp32 from sdkconfig". This I don't understand this because the target is set. Here are the relevant lines from my sdkconfig.
CONFIG_IDF_TARGET_ARCH_XTENSA=y
CONFIG_IDF_TARGET_ARCH="xtensa"
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_TARGET_ESP32=y
Minatel
Re: idf.py build errors/messages
Postby Minatel » Fri Dec 19, 2025 3:30 pm
Yes, this warning is related to the CMake version you are using, but it’s about the minimum version you declare vs. what ESP-IDF expects, not just “being current”.
Check on the CMakeLists.txt file
cmake_minimum_required(VERSION 3.22)
In ESP-IDF v5.0 the minimal supported CMake version was raised to 3.16 (and later to 3.22 in current docs). Versions lower than that are not supported.
When you don't specify the target by
idf.py set-target esp32
CMake falls back to reading the target from sdkconfig. This is expected behavior and does not mean your sdkconfig is wrong.
Users browsing this forum: PetalBot, Qwantbot and 2 guests
