ESP32C3 USB CDC loosing characters on reception of stream of data.
michalk
Re: ESP32C3 USB CDC loosing characters on reception of stream of data.
Postby michalk » Mon Jul 07, 2025 3:15 pm
I am having this problem as well:
usage:
    for (int i=0x0000; i<0x0004; i++){b = htonl(i);tusbwa1((const uint8_t *)&b, 4);}vTaskDelay(pdMS_TO_TICKS(100));
    for (int i=0x00F0; i<0x00F8; i++){b = htonl(i);tusbwa1((const uint8_t *)&b, 4);}vTaskDelay(pdMS_TO_TICKS(100));
    for (int i=0x0F00; i<0x0F0F; i++){b = htonl(i);tusbwa1((const uint8_t *)&b, 4);}vTaskDelay(pdMS_TO_TICKS(100));
    for (int i=0xF000; i<0xF00F; i++){b = htonl(i);tusbwa1((const uint8_t *)&b, 4);}vTaskDelay(pdMS_TO_TICKS(100));
method:
bool tusbwa1(const uint8_t* data, size_t len) {
    int max_retries = 100;
    size_t total_sent = 0;
    int retries = 0;
    while (total_sent < len) {
        vTaskDelay(pdMS_TO_TICKS(1));
        size_t sent = tinyusb_cdcacm_write_queue(TINYUSB_CDC_ACM_1, data + total_sent, len - total_sent);
        tud_remote_wakeup();
        if (sent == 0) {
            tinyusb_cdcacm_write_flush(TINYUSB_CDC_ACM_1, pdMS_TO_TICKS(100));
            retries++;
            if (retries > max_retries) {                return false;            }
        } else {
            total_sent += sent;
            retries = 0; // Reset retries after progress
    // tinyusb_cdcacm_write_flush(TINYUSB_CDC_ACM_1, pdMS_TO_TICKS(100));
    return true;
desktop:~$ cat /dev/ttyACM3 | xxd
00000000: 0000 0f00 000f 0500 000f 0600 000f 0700  ................
00000010: 000f 0800 000f 0900 000f 0a00 000f 0b00  ................
That's all of the output I get.
CORRECTION:
My problem is that cat /dev/ttyACM3 needed to have settings on the TTY for this to work properly.
stty -F /dev/ttyACM3 raw -echo
is required.
toybuilder
Postby toybuilder » Thu Nov 06, 2025 5:17 pm
Any update on this? I have the same issue on the ESP32-S3 at even modest rate of data transfer.
jared_s
Postby jared_s » Thu Nov 06, 2025 6:41 pm
Did you find a fix for your problem with CDC? I have a similar problem with MIDI on the OTG port of ESP32 P4.
See my post in this category.
J.
Danjovic
Postby Danjovic » Tue Jan 06, 2026 2:54 am
None, so far.
Danjovic
Postby Danjovic » Tue Jan 06, 2026 3:01 am
J.
The problem have been reported by Sprite to Espressif, but so far I have no feedback about the solution
As of today the list of chips with the same problem are :
-ESP32C3
-ESP32C6
-ESP32S3
-ESP32P4
