Program won't run ESP32
delcari
Postby delcari » Wed Jan 07, 2026 11:14 am
I've designed a custom PCB for the ESP32-S3-WROOM module and am having issues running the program. I have successfully flashed the board multiple times with code variations and settings to identify what the issue truly is. I'm unable to receive serial output or even set one of the pins high. I have tested with a multimeter to verify, so I believe it is a boot issue.
I am a bit of an amateur in a bit of a rush, this is my first custom ESP32 PCB so please outline any obvious flaws or potential mistakes thanks :)
Re: Program won't run ESP32
Postby Sprite » Thu Jan 08, 2026 1:41 am
First of all: remove C13. That capacitor will lead to issues with the chip going into download mode on power-on.
Secondly, when you say you don't get serial output, what exactly are the symptoms?
delcari
Postby delcari » Thu Jan 08, 2026 9:28 am
Sprite, thank you for your time and assistance, removal of that capacitor completely resolved all the problems I was having, it must've just been stuck in a download mode loop. May I ask the reason it did cycle with that capacitor in place? I'm very happy 😊
Postby Sprite » Fri Jan 09, 2026 12:00 am
The issue is that if you power it on, the capacitor will be empty, and until the 10K resistor can fully charge it, the voltage level on it will read as '0' putting the chip into download mode.
Users browsing this forum: Bing [Bot], PerplexityBot and 1 guest
