I have a custom PCB with a ESP32-S3-WROOM-1U module (N8R8), and i have dozens of devices in use for over a year without problem. A few are failing, with an unresponsive ESP32. I connect via native USB (also used to upload initial firmware, without problem).
On the serial port i get:
invalid header: 0xffffff7f
in a loop, and i when i reset with GPIO0 LOW, there is no output (not the usual 'waiting for download')
$ esptool.py --port /dev/ttyACM0 read_flash_status
esptool.py v3.3.3
Serial port /dev/ttyACM0
Connecting...
Detecting chip type... ESP32-S3
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 94:a9:90:0c:74:fc
Uploading stub...
Running stub...
Stub running...
Status value: 0x3f3f
Hard resetting via RTS pin...
$ esptool.py --port /dev/ttyACM0 erase_flash
esptool.py v3.3.3
Connecting...
Features: WiFi, BLE
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
"/home/tom/.arduino15/packages/esp32/tools/esptool_py/5.1.0/esptool" --chip esp32s3 --port "/dev/ttyACM0" --baud 115200 --before default-reset --after hard-reset write-flash -z --flash-mode keep --flash-freq keep --flash-size keep 0x0 "/home/tom/.cache/arduino/sketches/E3BB14F93F6F216769FCB480B2EBA599/Blink.ino.bootloader.bin" 0x8000 "/home/tom/.cache/arduino/sketches/E3BB14F93F6F216769FCB480B2EBA599/Blink.ino.partitions.bin" 0xe000 "/home/tom/.arduino15/packages/esp32/hardware/esp32/3.3.5/tools/partitions/boot_app0.bin" 0x10000 "/home/tom/.cache/arduino/sketches/E3BB14F93F6F216769FCB480B2EBA599/Blink.ino.bin"
esptool v5.1.0
Serial port /dev/ttyACM0:
Connecting...Traceback (most recent call last):
File "esptool/__init__.py", line 1173, in _main
File "esptool/__init__.py", line 1032, in main
File "esptool/cli_util.py", line 229, in __call__
File "rich_click/rich_command.py", line 404, in __call__
File "click/core.py", line 1442, in __call__
File "rich_click/rich_command.py", line 187, in main
File "click/core.py", line 1830, in invoke
File "click/core.py", line 1226, in invoke
File "click/core.py", line 794, in invoke
File "click/decorators.py", line 34, in new_func
File "esptool/__init__.py", line 688, in write_flash_cli
File "esptool/cmds.py", line 1112, in attach_flash
File "esptool/loader.py", line 1091, in flash_id
File "esptool/loader.py", line 1653, in run_spiflash_command
File "esptool/loader.py", line 901, in read_reg
File "esptool/loader.py", line 565, in check_command
File "esptool/loader.py", line 495, in command
File "esptool/loader.py", line 431, in read
StopIteration
A fatal error occurred: The chip stopped responding.
Connected to ESP32-S3 on /dev/ttyACM0:
Chip type: ESP32-S3 (QFN56) (revision v0.2)
Features: Wi-Fi, BT 5 (LE), Dual Core + LP Core, 240MHz, Embedded PSRAM 8MB (AP_3v3)
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
Uploading stub flasher...
Running stub flasher...
Stub flasher running.
Failed uploading: uploading error: exit status 2
"/home/tom/.arduino15/packages/esp32/tools/esptool_py/5.1.0/esptool" --chip esp32s3 --port "/dev/ttyACM0" --baud 921600 --before default-reset --after hard-reset write-flash -z --flash-mode keep --flash-freq keep --flash-size keep 0x0 "/home/tom/.cache/arduino/sketches/E3BB14F93F6F216769FCB480B2EBA599/Blink.ino.bootloader.bin" 0x8000 "/home/tom/.cache/arduino/sketches/E3BB14F93F6F216769FCB480B2EBA599/Blink.ino.partitions.bin" 0xe000 "/home/tom/.arduino15/packages/esp32/hardware/esp32/3.3.5/tools/partitions/boot_app0.bin" 0x10000 "/home/tom/.cache/arduino/sketches/E3BB14F93F6F216769FCB480B2EBA599/Blink.ino.bin"
esptool v5.1.0
Connecting...
A fatal error occurred: No serial data received.
Changing baud rate to 921600...
Thanks in advance - Tom
