adding lib to component trouble
zheckiss
Postby zheckiss » Wed Jul 09, 2025 3:35 am
Hi! I have component folder in my project It contains espressif__libpng, joltwallet__littlefs, lvgl__lvgl folders. I need to make libpng and littlefs to be visible for lvgl because cmake error:
Compilation failed because lv_libpng.c (in "lvgl__lvgl" component) includes png.h, provided by espressif__libpng component(s).
However, espressif__libpng component(s) is not in the requirements list of "lvgl__lvgl".
To fix this, add espressif__libpng to PRIV_REQUIRES list of idf_component_register call in D:\project\ESP32S3\MFM_01\components\lvgl__lvgl\CMakeLists.txt.
When I add
idf_component_register(
    PRIV_REQUIRES
        libpng )
to cmakelists.txt of lvgl folder I receive the next error:
CMake Error at C:/Users/malkov/esp/v5.3.1/esp-idf/tools/cmake/component.cmake:488 (add_library):
add_library cannot create target "__idf_lvgl__lvgl" because another target
with the same name already exists. The existing target is a static library
created in source directory
"D:/project/ESP32S3/MFM_01/components/lvgl__lvgl". See documentation for
policy CMP0002 for more details.
components/lvgl__lvgl/CMakeLists.txt:42 (idf_component_register)
please help me how to fix this?
MicroController
Re: adding lib to component trouble
Postby MicroController » Thu Jul 10, 2025 9:27 am
Just do what it says.
Open the CMakeLists.txt and add the PRIV_REQUIRES to the existing call to idf_component_register().
frhr
Postby frhr » Thu Jul 10, 2025 10:17 am
as MicroController already stated the dependency needs to be added to the lvgl cmake component registration.
I tried with hello_world project
  • $ idf.py add-dependency "espressif/libpng^1.6.39~1"
  • $ idf.py add-dependency "lvgl/lvgl^9.3.0"
  • $ idf.py menuconfig # Component config ---> LVGL configuration ---> 3rd Party Libraries ---> [x] PNG decoder(libpng) library
  • $ vim managed_components/lvgl__lvgl/env_support/cmake/esp.cmake
  idf_component_register(SRCS ${SOURCES} ${EXAMPLE_SOURCES} ${DEMO_SOURCES}
      INCLUDE_DIRS ${LVGL_ROOT_DIR} ${LVGL_ROOT_DIR}/src ${LVGL_ROOT_DIR}/../
                   ${LVGL_ROOT_DIR}/examples ${LVGL_ROOT_DIR}/demos
      PRIV_REQUIRES espressif__libpng
      REQUIRES esp_timer)
HTH
Mephisto75
Postby Mephisto75 » Sun Feb 08, 2026 2:31 pm
Hey, everyone,
I am having a few issues myself and therefore need you help!
Can you confirm that you were able to install 'espressif__libpng'?
will change the idf_component.yml but no matter what I do I can't get it to download espressif__ligpng into the managed_components folder.
I even deleted the build folder and tried
idf.py reconfigure
to download any missing parts, but still nothing.
Since you guys are obviously one step ahead, can you give a hint on how to install the component?
Many Thanks!
nopnop2002
Contact:
Postby nopnop2002 » Mon Feb 09, 2026 3:14 am
Create idf_component.yml in main directory.
## IDF Component Manager Manifest File
dependencies:
  espressif/libpng:
    version: "^1.6.39"
Execute command.
$ idf.py fullclean
$ rm dependencies.lock
$ idf.py build
$ ls -l managed_components/
total 8
drwxrwxr-x 4 nop nop 4096 Feb  9 12:15 espressif__libpng
drwxrwxr-x 4 nop nop 4096 Feb  9 12:15 espressif__zlib
Users browsing this forum: Applebot, Google [Bot] and 1 guest
