Default value of esp_err_t
floows-s
Postby floows-s » Sat Feb 21, 2026 1:29 pm
I want to start by saying i am a beginner...
Why is the default/first value of esp_err_t: ESP_OK?
That means if not handled correctly by some stupid overlooked thing it would be ESP_OK.
I would rather it be ESP_FAIL: its better that something goes right but it reports it as false (ESP_FAIL), then to have it go wrong but report that it got right (ESP_OK).
I ask this question not because i think it is wrong, but because i am genuinely curious why this is.
What are your thoughts on this? :D
pacucha42
Re: Default value of esp_err_t
Postby pacucha42 » Tue Feb 24, 2026 11:36 am
Hi @floows-s,
esp_err_t is defined as an integer value (typedef int esp_err_t), which in C-language means it is by default (== variable declared without explicit initial value):
  • 0 when declared as global or static variable
  • undefined value when used in a local context (eg variable inside a function)
To stay on the safe side, you should always initialize your esp_err_t instance with a specific default value (ESP_FAIL in your case).
Hope this helps.
Users browsing this forum: Bing [Bot], Bytespider and 1 guest
