ESP32-S3-CAM integrated LED
Louis92
Postby Louis92 » Fri Feb 27, 2026 10:49 am
Hi
I have one dev. kit labeled ESP32-S3-CAM N16R8 re 1.3
On the board there is a little LED about 2x2 mm white square, close right to two small LEDs, close pins on the right, above boot button
What is the corresponding GPIO number ? is it a three color LED ?
Louis
MicroController
Re: ESP32-S3-CAM integrated LED
Postby MicroController » Sat Feb 28, 2026 7:54 pm
Maybe this will help. (Indicates a white LED @ GPIO 48.)
Louis92
Postby Louis92 » Sun Mar 01, 2026 1:21 pm
Hi
I have tried GPIO 2, 4, 48 .... no success to blink the little LED
Louis
MicroController
Postby MicroController » Mon Mar 02, 2026 12:49 pm
It could also be a WS2812-type RGB LED. Maybe give that a try.
Louis92
Postby Louis92 » Mon Mar 02, 2026 1:21 pm
Hi I don't think so
A LED WS2812 is measuring 5x5 mm
The LED on my ESP32-S3-CAM is clearly smaller (about 2x 2 mm)
Louis
lbernstone
Postby lbernstone » Mon Mar 02, 2026 7:07 pm
It shouldn't be too hard to find, assuming it is connected to gpio.
https://wokwi.com/projects/455609184782083073
Louis92
Postby Louis92 » Mon Mar 02, 2026 9:43 pm
I have tried all the GPIO : (0 ... 21, 35 ... 42, 45, 47, 48) on my kit ESP32‑S3‑CAM UICPAL N16R8
No success
Conclusion : the small LED is probably not available for piloting
