ESP32P4 FUNCTION EV BOARD( A working example to display a name (text-hello world) on the LCD using the ESP32-P4 board.)
saichandu
Postby saichandu » Sun Mar 29, 2026 6:59 am
I am working with the ESP32-P4 Function EV Board, and I need GitHub example codes to test and verify the peripherals on this board.
Specifically, I am looking for:
1. Example projects to test peripherals such as GPIO, LCD display, and other interfaces.
2. A working example to display a name (text-hello world) on the LCD using the ESP32-P4 board.
Any reference links, GitHub repositories, or sample codes would be greatly appreciated. please provide me to pratice
Thank you.
nopnop2002
Contact:
Re: ESP32P4 FUNCTION EV BOARD( A working example to display a name (text-hello world) on the LCD using the ESP32-P4 boar
Postby nopnop2002 » Mon Mar 30, 2026 3:13 am
Example code for hd44780
https://github.com/esp-idf-lib/hd44780
saichandu
Postby saichandu » Mon Mar 30, 2026 5:30 am
when I take a project from git, target is not detected what is the reason for this. how can i solve
iam using Espressif IDE
board-> esp32p4-function-ev-board. please give me clarity about these things
TARGET IS NOT DETECTED.. SEE THE SCREENSHOT OF IDE AND GIVE SUGGESTION
TOOL CHAIN IS NOT DETESTED.jpg (247.81 KiB) Viewed 173 times
nopnop2002
Contact:
Postby nopnop2002 » Mon Mar 30, 2026 2:22 pm
git clone https://github.com/esp-idf-lib/hd44780
cd hd44780/
cd examples/
cd default/
idf.py set-target esp32p4
idf.py build
