i have esp32-p4, on arduino core 3.3.7 not work, not compile with an erreur CPUFreq, but compil and work with core 3.3.6.
Thanks for your help.
ESP32-P4 dev module not work with core 3.3.7
andromeda92
lbernstone
Re: ESP32-P4 dev module not work with core 3.3.7
In 3.3.7, you must choose the correct "chip variant" for the P4 in the tools menu. It will default to >v3. The original chips run at a different clock speed.
andromeda92
the chip variant is for the version of the core > 3 or the version of P4 ?
lbernstone
It is a separate option in the menu that only shows up for P4 after core 3.3.6.
andromeda92
thanks, but after downgrade and after upgrade to 3.3.7 it work.
