I am currently working on a BLE Mesh + GATT coexistence architecture on ESP32 devices and would like to understand the architectural limitations and production viability of this approach on ESP-IDF.
### Background
Initially, I used an ESP32 DevKit (BLE 4.2 based controller). I observed that BLE Mesh and GATT operations could run together only through time-sliced scheduling. However, under heavy coexistence scenarios, I noticed delays and advertisement interruptions.
Later, I moved to the ESP32-C6 (BLE 5.0 capable controller) expecting improved coexistence performance due to BLE 5 features such as extended advertising and multiple PHY support.
### Current Scenario
My application involves:
* BLE Mesh provisioning (Remote Provisioning Client/Server)
* Simultaneous GATT server connection with a smartwatch/watch application
* Continuous BLE advertisement visibility
Current behavior:
1. On startup, everything works correctly:
* Watch connects through GATT
* Mesh provisioning succeeds
* Mesh communication works
2. Problem occurs after reconnect scenarios:
* If the watch disconnects/restarts, the ESP32-C6 stops appearing in BLE scan logs
* Advertisement becomes invisible both:
* on the watch side
* and on mobile apps such as Nordic nRF Connect
* Mesh functionality may still continue internally, but GATT advertising disappears
### Comparison with Nordic nRF53
I have previously worked with the nRF53 series running Zephyr/Nordic BLE architecture.
On Nordic:
* BLE Mesh and GATT coexist much more smoothly
* Multiple PHYs (1M / 2M) appear to operate simultaneously without noticeable delay
* Advertising and connections remain stable even during mesh operations
* Reconnection behavior is reliable
This made me question whether the limitation is:
* related to ESP32-C6 controller architecture,
* ESP-IDF BLE stack design,
* NimBLE integration limitations,
* scheduler/resource allocation,
* or simply current SDK maturity.
### My Questions
1. Does ESP32-C6 hardware architecture truly support stable simultaneous BLE Mesh + GATT coexistence in production environments?
2. Even though ESP32-C6 supports BLE 5.0, does ESP-IDF currently implement coexistence differently compared to Nordic’s Zephyr-based architecture?
3. Is BLE Mesh + GATT on ESP32 fundamentally dependent on time-sliced radio scheduling rather than parallel operation?
4. Does ESP32-C6 internally share a single radio pipeline between:
* Mesh advertisements
* GATT advertisements
* Connections
* Scanning
causing advertisement starvation under certain conditions?
5. Are there known limitations in ESP-IDF v5.4.1 related to:
* extended advertising,
* NimBLE coexistence,
* mesh + GATT simultaneous operation,
* or advertisement restart handling?
6. If coexistence is achieved through careful timing/scheduling only:
* Is this considered production-grade?
* Or can it later introduce hard-to-debug issues such as:
* missed advertisements,
* reconnect instability,
* mesh latency,
* random disconnections,
* watchdog issues,
* or resource starvation?
7. Has anyone successfully deployed a stable production product on ESP32-C6 with:
* continuous BLE Mesh,
* active GATT connections,
* persistent advertising,
* and reliable reconnect handling simultaneously?
I would appreciate architectural-level insights rather than only example-based solutions, especially from developers who have worked with both Nordic and Espressif BLE ecosystems.
ESP32 C6 BLE CoEx
Return to “General Discussion”
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User and 3 guests
- All times are UTC
- Top
- Delete cookies
About Us
Information
