Migration to 6.0.1
ViennaTom
Migration to 6.0.1
Postby ViennaTom » Sun Jun 14, 2026 10:54 pm
After some headaches i managed to shift my application to 6.0.1.
BUT ACTUALLY i had to fight two ugly facts:
configTASK_NOTIFICATION_ARRAY_ENTRIES defaults to 1 EVEN THOUGH drivers (like uart) require this to be at least 2 .....
The new CAN implementation uses twai_onchip_node_config_t which has no default initialization.
Hence new members
node_config.io_cfg.quanta_clk_out
node_config.io_cfg.bus_off_indicator
are initialized to 0 which causes GPIO0 to be driven unintentionally.
Took me some time to find out why my modbus communication died whenever CAN driver was initialized :-)
Another problem ocurred with old STM32 modules causing brownouts with WIFI which they did NOT with 5.5.4 ! Even placing a huge capacitor did not help. On newer ESP32 modules and fortunately with my Custom PCB this was not an issue.
- So please revert the default configTASK_NOTIFICATION_ARRAY_ENTRIES back to 2. If one has to save 4 Bytes a task he can lower to 1 :-)
- Provide an initialization MACRO or a default constructor for twai_onchip_node_config_t !
Greets, Tom
mikemoy
Re: Migration to 6.0.1
Postby mikemoy » Wed Jul 01, 2026 2:29 am
Hi Tom. Why aren't you just creating your own sdkconfig.tom.defaults file and put in there
CONFIG_FREERTOS_TASK_NOTIFICATION_ARRAY_ENTRIES=2
That way you never have to worry about it.
