Custom board error
seopyoon
Custom board error
Postby seopyoon » Thu Oct 12, 2017 10:28 am
Hello Espressif,
I have made a new custom board. It is an updated version with more peripherals, such as colour sensor, etc. (It uses WROOM-32 module)
I am getting a new error. I do not know what may have gone wrong. I am consulting the circuit company, but in the meantime, your help is greatly appreciated.
First,
When I connect the board and look at terminal, I get,
flash read err, 1000
then repeats.
So, I try flashing, and I get,
Warning: Could not auto-detect ...
Flash params set to 0x0220
A fatal error occurred: Time out waiting for packet content.
When I do efuse, I get:
Security fuses:
FLASH_CRYPT_CNT        Flash encryption mode counter                     = 0 R/W (0x0)
FLASH_CRYPT_CONFIG     Flash encryption config (key tweak bits)          = 0 R/W (0x0)
CONSOLE_DEBUG_DISABLE  Disable ROM BASIC interpreter fallback            = 0 R/W (0x0)
ABS_DONE_0             secure boot enabled for bootloader                = 0 R/W (0x0)
ABS_DONE_1             secure boot abstract 1 locked                     = 0 R/W (0x0)
JTAG_DISABLE           Disable JTAG                                      = 0 R/W (0x0)
DISABLE_DL_ENCRYPT     Disable flash encryption in UART bootloader       = 0 R/W (0x0)
DISABLE_DL_DECRYPT     Disable flash decryption in UART bootloader       = 0 R/W (0x0)
DISABLE_DL_CACHE       Disable flash cache in UART bootloader            = 0 R/W (0x0)
BLK1                   Flash encryption key
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLK2                   Secure boot key
BLK3                   Variable Block 3
Efuse fuses:
WR_DIS                 Efuse write disable mask                          = 0 R/W (0x0)
RD_DIS                 Efuse read disablemask                            = 0 R/W (0x0)
CODING_SCHEME          Efuse variable block length scheme                = 0 R/W (0x0)
KEY_STATUS             Usage of efuse block 3 (reserved)                 = 0 R/W (0x0)
Config fuses:
XPD_SDIO_FORCE         Ignore MTDI pin (GPIO12) for VDD_SDIO on reset    = 0 R/W (0x0)
XPD_SDIO_REG           If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset   = 0 R/W (0x0)
XPD_SDIO_TIEH          If XPD_SDIO_FORCE & XPD_SDIO_REG, 1=3.3V 0=1.8V   = 0 R/W (0x0)
SPI_PAD_CONFIG_CLK     Override SD_CLK pad (GPIO6/SPICLK)                = 0 R/W (0x0)
SPI_PAD_CONFIG_Q       Override SD_DATA_0 pad (GPIO7/SPIQ)               = 0 R/W (0x0)
SPI_PAD_CONFIG_D       Override SD_DATA_1 pad (GPIO8/SPID)               = 0 R/W (0x0)
SPI_PAD_CONFIG_HD      Override SD_DATA_2 pad (GPIO9/SPIHD)              = 0 R/W (0x0)
SPI_PAD_CONFIG_CS0     Override SD_CMD pad (GPIO11/SPICS0)               = 0 R/W (0x0)
DISABLE_SDIO_HOST      Disable SDIO host                                 = 0 R/W (0x0)
Identity fuses:
MAC                    MAC Address                                       = 24:0a:c4:05:15:a4 R/W
CHIP_VERSION           Chip version                                      = 0 R/W (0x0)
CHIP_PACKAGE           Chip package identifier                           = 0 R/W (0x0)
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).
Please any insight may be helpful in resolving the issue.
Thanks.
WiFive
Re: Custom board error
Postby WiFive » Thu Oct 12, 2017 10:51 am
What does it say for boot mode?
seopyoon
Postby seopyoon » Fri Oct 13, 2017 2:29 am
Sorry, boot mode?
When I connect the chip, I get,
rst:0x10 (RTCWDT_RTC_RESET), boot:0x32 (SPI_FAST_FLASH_BOOT)
Failing back to built-in command interpreter
OK
repeats.
WiFive
Postby WiFive » Fri Oct 13, 2017 3:01 am
Yes boot mode is
This shows that gpio12/mtdi strapping pin is pulled up causing 1.8v on vdd_sdio but the wroom32 needs 3.3v so either pull it low or set efuse for 3.3v.
seopyoon
Postby seopyoon » Fri Oct 13, 2017 3:45 am
I had my GPIO12 pulled up, which caused the error.
(Please could someone let me know why that is the problem? GPIO12 is used for something on boot? I got the idea of pulling it down from a third party chip maker, https://cdn-learn.adafruit.com/download ... eather.pdf page 12)
Thanks.
WiFive
Postby WiFive » Fri Oct 13, 2017 4:00 am
Esp32 datasheet section 2.4 strapping pins
seopyoon
Postby seopyoon » Fri Oct 13, 2017 1:04 pm
Could it be pulled up after it boots? It seems to be okay when I try, but could it be a problem?
WiFive
Postby WiFive » Fri Oct 13, 2017 10:22 pm
It could be a problem if chip resets and it stays pulled up. Try efuse.
Users browsing this forum: Google [Bot], Qwantbot and 2 guests
