ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x5 (DSLEEP),boot:0xa (SPI_FAST_FLASH_BOOT)
pro cpu reset by JTAG
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x159c
load:0x403c8700,len:0xd24
load:0x403cb700,len:0x2fa0
entry 0x403c8924
I (26) boot: ESP-IDF v5.5 2nd stage bootloader
I (26) boot: compile time Jul 31 2026 11:41:32
I (27) boot: Multicore bootloader
I (27) boot: chip revision: v0.2
I (29) boot: efuse block revision: v1.4
I (33) boot.esp32s3: Boot SPI Speed : 80MHz
I (37) boot.esp32s3: SPI Mode : DIO
I (41) boot.esp32s3: SPI Flash Size : 4MB
I (44) boot: Enabling RNG early entropy source...
I (49) boot: Partition Table:
I (51) boot: ## Label Usage Type ST Offset Length
I (58) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (64) boot: 1 otadata OTA data 01 00 0000f000 00002000
I (71) boot: 2 phy_init RF data 01 01 00011000 00001000
I (77) boot: 3 ota_0 OTA app 00 10 00020000 001a9000
I (84) boot: 4 ota_1 OTA app 00 11 001d0000 001a9000
I (90) boot: End of partition table
I (94) esp_image: segment 0: paddr=00020020 vaddr=3c090020 size=21358h (136024) map
I (125) esp_image: segment 1: paddr=00041380 vaddr=3fc9ac00 size=04788h ( 18312) load
I (129) esp_image: segment 2: paddr=00045b10 vaddr=40374000 size=0a508h ( 42248) load
I (139) esp_image: segment 3: paddr=00050020 vaddr=42000020 size=82460h (533600) map
I (233) esp_image: segment 4: paddr=000d2488 vaddr=4037e508 size=0c6c8h ( 50888) load
I (244) esp_image: segment 5: paddr=000deb58 vaddr=600fe000 size=00080h ( 128)
I (259) boot: Loaded app from partition at offset 0x20000
I (259) boot: Disabling RNG early entropy source...
I (269) cpu_start: Multicore app
I (278) cpu_start: Pro cpu start user code
I (278) cpu_start: cpu freq: 160000000 Hz
I (278) app_init: Application information:
I (278) app_init: Project name: Milkhub-Wireless-Keypad
I (283) app_init: App version: 7007a39-dirty
I (287) app_init: Compile time: Jul 31 2026 12:28:24
I (293) app_init: ELF file SHA256: 7d3508860...
I (297) app_init: ESP-IDF: v5.5
I (300) efuse_init: Min chip rev: v0.0
I (304) efuse_init: Max chip rev: v0.99
I (308) efuse_init: Chip rev: v0.2
I (312) heap_init: Initializing. RAM available for dynamic allocation:
I (318) heap_init: At 3FCA3578 len 00046198 (280 KiB): RAM
I (324) heap_init: At 3FCE9710 len 00005724 (21 KiB): RAM
I (329) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (334) heap_init: At 600FE080 len 00001F68 (7 KiB): RTCRAM
I (340) spi_flash: detected chip: gd
I (343) spi_flash: flash io: dio
I (346) sleep_gpio: Configure to isolate all GPIO pins in sleep state
I (352) sleep_gpio: Enable automatic switching of GPIO sleep configuration
I (359) main_task: Started on CPU0
I (369) main_task: Calling app_main()
I (369) msg_router: Version 0.1-1
I (369) msg_router: Wake cause: 7
void app_main(void)
ESP_LOGI(TAG, "Version %d.%d-%d", SW_VER_MAJOR, SW_VER_MINOR, SW_VER_REV);
ESP_LOGI(TAG, "Wake cause: %d", esp_sleep_get_wakeup_cause());
ESP_SLEEP_WAKEUP_GPIO, //!< Wakeup caused by GPIO (light sleep only on ESP32, S2 and S3)
