rtc_clk_cpu_freq_set() lockups
Re: rtc_clk_cpu_freq_set() lockups
permal: I'll talk to hardware colleagues to see if they can offer a way to diagnose this issue by running some code on your side. Even if this is a hardware issue, we would like to understand the failure mode better.
Ok, I'm up for that.permal: I'll talk to hardware colleagues to see if they can offer a way to diagnose this issue by running some code on your side. Even if this is a hardware issue, we would like to understand the failure mode better.
If I understand this correctly, this issue can happen also at a later time, right? I.e. the PLL getting out of phase long after reboot? (yes, I am getting lockups with the exact same behavior).
ESP_iggr, any update on this? I'm still willing to run some diagnostics.
Do you happen to have a scope which can display 80/160/320 MHz signal? Or a frequency meter? We can pull out these clocks to a pad and check whether PLL is working or not.
Sadly, no. My Rigol 1054z has a bandwidth of 100Mhz, so those frequencies are a bit too high to show the true signal form.
Ok, i think it will still be good enough to show presence/absence of clock signal.
Could you please add the following at the start of esp_clk_init function ($IDF_PATH/components/esp32/clk.c):
And then the second test with sig_num = 13.
Value 8 should route the 80MHz clock divided from the PLL, to GPIO0. Value 13 should route 80 or 160MHz clock, depending on the selected CPU frequency.
The result i expect is that when you see that the chip locks up, no clock will be observed on GPIO0 (both in the case of sig_num=8 and sig_num=13). If this is the case, we will proceed to troubleshoot PLL configuration. If this is not the case, we will need to think what else can cause the lock-up.
const int sig_num = 8;
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
REG_WRITE(PIN_CTRL, sig_num);
Igrr,
With sig_num = 8 and freq set at 80MHz, I only got noise on GPIO0. Both in functional and non-functional state. However, with sig_num = 13, I got this at 80MHz. The device is in a working state (blinking a LED on GPIO5) When hung, it looks pretty much the same, though the duty cycle is then exactly 50/50 compared to the previous image where it actually differs over time by up to 2%. Results for 160MHz in the next post (can only add three images it seems)
Increasing freq to 160MHz gives the following result. Still a 80MHz signal(I double checked the freq setting to make sure it is at 160MHz)
And for completeness, here is sample where it is hung with freq set at 160MHz. Again, 80MHz signal.
Fwiw, the last few days I've started seeing the lockup also at 240MHz. Same h/w as previously.
esptool.py v2.1
Flashing app to serial port /dev/ttyUSB0, offset 0x10000...
esptool.py v2.1
Connecting........__
Chip is ESP32D0WDQ6 (revision 0)
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 945200 bytes to 529307...
Wrote 945200 bytes (529307 compressed) at 0x00010000 in 11.4 seconds (effective 665.6 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting...
MONITOR
--- idf_monitor on /dev/ttyUSB0 115200 ---
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:5544
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:12484
entry 0x40078f7c
W (55) rtc_clk: Possibly invalid CONFIG_ESP32_XTAL_FREQ setting (26MHz). Detected 26 MHz.
I (39) boot: ESP-IDF v3.0-dev-960-g6cc8099 2nd stage bootloader
I (39) boot: compile time 10:16:59
I (48) boot: Enabling RNG early entropy source...
I (48) boot: SPI Speed : 40MHz
I (49) boot: SPI Mode : DIO
I (53) boot: SPI Flash Size : 4MB
I (57) boot: Partition Table:
I (61) boot: ## Label Usage Type ST Offset Length
I (68) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (76) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (83) boot: 2 factory factory app 00 00 00010000 00100000
I (90) boot: End of partition table
I (95) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2bf3c (180028) map
I (139) esp_image: segment 1: paddr=0x0003bf64 vaddr=0x3ffb0000 size=0x03408 ( 13320) load
I (142) esp_image: segment 2: paddr=0x0003f374 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at /home/permal/esp/esp-idf/components/freertos/./xtensa_vectors.S:1685
I (146) esp_image: segment 3: paddr=0x0003f77c vaddr=0x40080400 size=0x00894 ( 2196) load
I (155) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0xa72c4 (684740) map
0x400d0018: _flash_cache_start at ??:?
I (297) esp_image: segment 5: paddr=0x000e72e4 vaddr=0x40080c94 size=0x0f918 ( 63768) load
I (311) esp_image: segment 6: paddr=0x000f6c04 vaddr=0x400c0000 size=0x00000 ( 0) load
I (315) boot: Loaded app from partition at offset 0x10000
I (315) boot: Disabling RNG early entropy source...
I (321) cpu_start: Pro cpu up.
I (325) cpu_start: Starting app cpu, entry point is 0x40080f3c
0x40080f3c: call_start_cpu1 at /home/permal/esp/esp-idf/components/esp32/./cpu_start.c:222
I (0) cpu_start: App cpu up.
I (335) heap_init: Initializing. RAM available for dynamic allocation:
D (342) heap_init: New heap initialised at 0x3ffae6e0
I (347) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
D (353) heap_init: New heap initialised at 0x3ffba448
I (358) heap_init: At 3FFBA448 len 00025BB8 (150 KiB): DRAM
I (364) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (371) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
D (378) heap_init: New heap initialised at 0x400905ac
I (382) heap_init: At 400905AC len 0000FA54 (62 KiB): IRAM
I (388) cpu_start: Pro cpu start user code
D (400) clk: RTC_SLOW_CLK calibration value: 3251909
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User, Google [Bot], Semrush [Bot] and 1 guest
